Old August 19, 2007, 07:37 AM
3.0charlie's Avatar
Originally Posted by Corpus Masochist View Post
Looking at my system some more and noticed that if I had 90 degree barbs facing striaght up that would help a great deal with the amount of tubing I use at the back and also would eliminate any kinking (although I wouldn''t let that happen.)
I am looking around for a couple 90 degree barb, I found these http://www.ncix.com/products/index.p...cture=Koolance but I'm not sure if the OD is correct. I am thinking about looking at home depot or a plumbing shop?
Like MPG said, if you have clearance for 2 holes and go through the case lower (having the barbs on the bottom of the rad), I'd go for that.
As for 90* elbows, you need those: http://www.ncix.com/products/index.p...e=Danger%20Den
The Koolance elbows are specific for the Koolance systems.
John
edit: forgot to add that once the 2 holes are drilled and that the 2 grommets (the 2 black rubber pieces) are installed, if you want to easily install the tubing: simply wet the inside of the grommets with regular water. The tubing will slide easily.
Old August 19, 2007, 11:44 AM
Misoprostol
Guest
Posts: n/a
These are cool, but you need barbs in addition to the delrin 90.
Old August 19, 2007, 11:48 AM
sswilson's Avatar
No way to mount those directly to the rad is there?
Old August 19, 2007, 02:37 PM
MpG's Avatar
MpG MpG is offline
Danger Den G1/4 High Flow Fitting - Male to Male Thread
The Swifttech rads are all g1/4 now, right? PPC has these double-male G1/4 fittings available which would probably do the trick. Never seen them available up here in Canada, tho. And no bets on what direction the elbow would be aimed once you finished tightening them down.
Acer to enter Console Market? Babrbarossa Rumor Mill 10 April 19, 2008 05:22 PM
Can you believe spacial problems with a Lian Li v2000II plus Corpus Masochist Cases 35 August 14, 2007 09:22 AM
Lian Li PC-343B Modular Cube Case: review by PCApex Babrbarossa Reviews & Articles from the Web 1 March 28, 2007 12:41 AM
