Old September 9, 2009, 05:26 AM
Deeival's Avatar
Default CPU block for LGA1156?
I can't seem to find any on NCIX. Or do the LGA1366 ones generally fit on a LGA1156 board?
Can you generally remove the barb fittings from CPU/GPU blocks? I was gonna take those out and use compression fittings.
Thanks
Old September 9, 2009, 07:32 AM
Akai's Avatar
Not sure if 1156/1366 are the same mounts but I doubt it.
However I do remember reading about a P55 1156 motherboard which had 755 mounts as well, cant remember the brand i think maybe Gigabyte. It was one of what seems like hundreds of motherboard previews i went thru in the past few months lol If you grab one of those you could just use a 775 waterblock. Otherwise i think your gonna have to wait for mounting adapters to filter thru the retail channels.
Old September 9, 2009, 09:37 AM
im prety sure(99.9%) the the ek supreme lt will fit lga1156
Old September 9, 2009, 10:19 AM
Neolithium_Wpg's Avatar
Koolance lists new brackets for LGA1156 due at the end of september.
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old September 9, 2009, 11:54 AM
As Akai mentioned sone P55 mobos do have holes for LGA775 cooler/mounting compatibility.. Saw them in some mobo previews, I wish I could remember which ones..
Old September 9, 2009, 12:55 PM
IIRC it was some of the EVGA lineup
-Author Unknown
Old September 9, 2009, 08:45 PM
Akai's Avatar
that sounds about right... its a nice touch if you ask me for capturing those looking to upgrade so they dont have to replace their current blocks/heatsinks
Old September 9, 2009, 09:41 PM
Linus's Avatar
The Danger Den LGA775 universal hold down fits on 1156. I was using one when I was working on my overclocking guide.
It was the steel version of the hold down. We don't carry it anymore though...
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old September 10, 2009, 08:16 AM
mattlef's Avatar
Will most 775 brackets fit a 1156 socket?
CC-HotSpot Host
YouTube Instagram Twitter
Old September 10, 2009, 10:08 AM
Sagath's Avatar
No, the 775 holes are just slightly 'out' more then the 1156. By like 1/2 cm. Dumb move by intel. No reason they couldnt have made the hole spacing the same.I have to wonder if intel got bought off by one/all of the aftermarket cooler companies
CPU and cpu block questions miggs78 Water Cooling 7 August 10, 2009 01:14 AM
New CPU Block required Wall86 Water Cooling 5 July 11, 2009 11:54 PM
[WTB] Cpu block donkon Buy/Sell & Trade 1 May 15, 2009 09:09 AM
[WTB] CPU Water Block Lpfan4ever Buy/Sell & Trade 10 March 4, 2009 07:00 AM
Enzotech SCW-1 Sapphire CPU Block JD Water Cooling 2 November 23, 2007 11:29 PM
