  #21 (permalink)
Old September 5, 2009, 05:10 AM
gingerbee's Avatar
just for reference there is no difference in the temps when mounting it "right" have had it both ways for my i7 and temps were the same
  #22 (permalink)
Old September 5, 2009, 07:34 AM
Sagath's Avatar
I agree with this. I've done the same thing with my GTZ, correcting it after I noticed it while making some loop changes. Exact same temps both before, and after.
  #23 (permalink)
Old September 5, 2009, 07:56 AM
Thanks for the heads up guys, now I don't have to worry about remounting the GTZ to see if I get different temps. I will just report my temps with HK3 running Prime95 on 8 threads for 10 or 12 hours (depends on when I get home). It's running right now as I'm at work.
Intel i7 5960x @ 4.5Mhz | MSI X99S Gaming 9 ACK
32Gb G.Skill Trident RGB @3000Mhz | Asus STX audio
Gigabyte RX Vega 64 | Samsung CF791 Ultrawide 1440p (main) Yamakasi Q270 Catleap 2b @1440p (secondary)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache | Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK RX Vega WB | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad | Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
  #24 (permalink)
Old September 5, 2009, 04:58 PM
astrodanco's Avatar
@ontariotl, you're able to overclock with a very low vcore, hence low temps. Either you have a magic chip or you have a real knack for tweaking your BIOS settings. Could you please share ALL your AI Overclock BIOS settings with us?
  #25 (permalink)
Old September 5, 2009, 06:36 PM
Sagath's Avatar
eh? Its a D0, those volts seem reasonable for a 4 to 4.2ghz overclock. I'm running 4.0 plus turbo at 1.2275v. Most D0's seem to have no issues hitting 3.8+ with <1.3v
  #26 (permalink)
Old September 5, 2009, 07:26 PM
astrodanco's Avatar
Eh what? I have a D0 here on a P6T Deluxe V2. Nothing magic about D0. At 4.0 GHz I need 1.32V in order to remain rock solid stable for more than just a few hours under maximum load. I use OCCT's cpu:linpack mode to test full load stability. I haven't found any other test that stresses the system more than that one does. Perhaps you guys don't test your overclocks under maximum load for more than a few hours? Is that your secret? You don't run 24/7 overclocked? On the other hand, I may have a real dud of a D0!
I would really, really, really like to know ALL your settings for achieving rock solid stability at those overclocks, particularly if changing some other setting will allow me to lower my vcore. I want to reach 4.2 GHz at low vcore too. Please tell me your secret!
  #27 (permalink)
Old September 5, 2009, 08:04 PM
Sagath's Avatar
Sorry, I'm not against what you're asking, I just dont understand how you think there is a magic bios setting you're missing that will let you lower your cpu .05v. Your chip isnt the benchmark of all D0's, not all chips need >1.3v. Nor are ours the benchmark of <1.3v. However, as I said, alot of D0's on the net are getting those <1.3v numbers. Thus my 'eh'.
The logic you're applying to his chip being a 'magic' rare one could absolutely be applied to the fact your chip needs more volts then his, or mine. Not all chips are equal. Maybe you did get a bit worse of a D0. *shrug* Luck of the draw, isnt it?
  #28 (permalink)
Old September 5, 2009, 08:29 PM
stoanee's Avatar
Do you have the latest bios on your board? That helped me get to 4 ghz stable.
heatware
  #29 (permalink)
Old September 5, 2009, 09:06 PM
astrodanco's Avatar
Yes and I am at 4 GHz stable, just with a higher vcore than people who say it can be done with a low vcore are using. Higher vcore results is higher core temperatures. I'd very much like to be able to run at 4 GHz with low vcore too and am wondering if there is some other setting that I am overlooking that helps to achieve that.
  #30 (permalink)
Old September 5, 2009, 09:10 PM
stoanee's Avatar
Probably your chip. What batch#?
heatware
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
[FS] HeatKiller 285 and 295 GPU blocks Liu Kang Buy/Sell & Trade 9 July 28, 2009 04:09 PM
HeatKiller CPU blocks: share your results Liu Kang Water Cooling 8 July 28, 2009 05:11 AM
[FS] NEW, HEATKILLER GPU-X GTX 285 waterblock Liu Kang Buy/Sell & Trade 1 July 12, 2009 06:01 AM
LF: HR-03 GT / Accelero S1 rev. 2 cegras Buy/Sell & Trade 12 September 1, 2008 12:27 AM
