Old September 4, 2009, 09:56 AM
gingerbee's Avatar
Originally Posted by ontariotl View Post
Sure I can run it for 12 and give you the results. Just can't do the GTZ since its now retired.
Just wondering what the slow climb in temps will be? i know what my gtz does thank
Old September 4, 2009, 10:50 AM
Is there a program that will record temps as time progresses?
Intel i7 5960x @ 4.5Mhz | MSI X99S Gaming 9 ACK
32Gb G.Skill Trident RGB @3000Mhz | Asus STX audio
Gigabyte RX Vega 64 | Samsung CF791 Ultrawide 1440p (main) Yamakasi Q270 Catleap 2b @1440p (secondary)
Samsung 950 Pro m.2 @ Gen3 x4 32Gbps | Seagate 4Tb with 256 SSD cache | Corsair Obsidian 800D | Seasonic X-1250
HeatKiller 3.0 | EK RX Vega WB | TFC Exchanger Quad Rad |Thermochill PA120.3 rad|TFC Dual rad | Scythe Gentle Typhoon (x9) |Swiftech MCP655 (x2) | Koolance bay Resevior
Old September 4, 2009, 10:52 AM
Originally Posted by Dazmode View Post
This block look so good installed! I keep hypnotizing myself: "I like my Supreme", but it gets harder and harder for me. Damn you!
Hey I blame you for getting them in stock and lightening my wallet. But, for once I can happily say I was glad I made an upgrade.
Old September 4, 2009, 11:13 AM
gingerbee's Avatar
just use real temp it will read the max. even if it's only for 1 second that the temp goes that high ( i.e you will see what it tops out at peak )
Old September 4, 2009, 10:38 PM
Alright, I've been watching all this hub bub with this Heatkiller rev 3.0 and its dramatic drops in temperature compared to my trusty Swiftech Apogee GTZ. I fell for the hype when I upgraded from the GTX to GTZ. I didn't see that much improvement to even be at least satisfied with the upgrade.
in 775 and 1366 flavors. Damn I even still have my GTX. Time for another long post
You have the orientation wrong on the GTZ mount, instructions say its important and will effect temps.
Don't know how much of a difference it will make, but there must be a reason for them specifying this.
▀olweval
Browser: Intel QX9650 (3.0GHz) | Noctua NH-C12P R | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | MSI 8800 GT | Customized Antec Super Lan Boy | Antec Signature SG850 PSU | Ubuntu x64 9.04
Gamer: Intel i7 920 (2.66) @ 3.6 | Water Cooled Buy Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
Old September 4, 2009, 11:00 PM
MpG's Avatar
MpG MpG is offline
It has to do with aligning the impingement pattern of the block with how the cores in the i7 CPU are arranged. While I can believe it makes a difference, I'd honestly be surprised if it amounted to more than a degree or two, not nearly the difference that his testing gave him.
Old September 4, 2009, 11:41 PM
Yeah, Everest has HTML logging and you can set the intervals I believe. Before I hag a G15 to output my temps I used to turn logging on and log my GPU diode temps and Core temps and see what they peaked at. It'll give you peak, minimum, average etc as well as temps every 5 seconds.
Old September 4, 2009, 11:59 PM
sswilson's Avatar
Damn that is one sweet looking block, and it appears to offer both performance and beauty.
Not sure I can justify spending $100+ for S775 (or my new AM3), but it definately looks like a winner for the hotter i7 platform.
  #19 (permalink)
Old September 5, 2009, 01:01 AM
MpG's Avatar
MpG MpG is offline
Realtemp will record temps in a .csv file, in whatever directory the realtemp files are, and that file can be pulled up with Excel easily. You'll want to erase the old .csv file first, though, as Realtemp just keeps on adding to it, until you grab the file and move it elsewhere.
  #20 (permalink)
Old September 5, 2009, 03:49 AM
You make a valid point and I didn't catch the mistake until you pointed it out. I had it properly arranged when I had my Quad core, but I mounted it incorrectly in my haste to get my new i7 Core up and running. Although mind you, those recommendations were for the Quad since it was a 2 chip chip design. With i7 Core, it is back to a one chip design which probably wont affect the GTZ as much. It's the inlet that is the most important factor. Good observation, and it almost makes me want to reinstall the GTZ to retest. Just not as easy as it is air cooling to set it all up again, but I'm not here to b.s. anyone.
MPG, thanks for the info on the .csv file for real temp. I may use it for my updated tests.
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
[FS] HeatKiller 285 and 295 GPU blocks Liu Kang Buy/Sell & Trade 9 July 28, 2009 04:09 PM
HeatKiller CPU blocks: share your results Liu Kang Water Cooling 8 July 28, 2009 05:11 AM
[FS] NEW, HEATKILLER GPU-X GTX 285 waterblock Liu Kang Buy/Sell & Trade 1 July 12, 2009 06:01 AM
LF: HR-03 GT / Accelero S1 rev. 2 cegras Buy/Sell & Trade 12 September 1, 2008 12:27 AM
