Old August 30, 2009, 11:00 PM
kyle_L's Avatar
Default how do thermoelectric coolers work
i think i know how it works but can someone clarify how it work for me. i dont need a big long explanation something short and simple will work. and will having multiple tec's modded into one loop improve cooling. just need some these questions answered in regards to my next build. thanks to all who can help me.
Gotta Love Timmies Coffee.
Old August 30, 2009, 11:10 PM
the second law of thermodynamics Says that heat will move to a cooler area. Essentially, the module will absorb heat on the "cold side" and eject it out the "hot side" to a heat sink. The heat sink must be capable of dissipating the electrical power applied to the module, which also exits through the modules hot side.
Death to Apple
Old August 31, 2009, 04:26 PM
KaptCrunch's Avatar
only con is need extra PSU to run your TEC and good cooling hardware to get any good results with peltier set-ups
melcor is good supplier (free samples)
how tec works
Old August 31, 2009, 07:02 PM
kyle_L's Avatar
well thanks for the help guy's, i get it now.
Old September 1, 2009, 08:54 AM
BrainEater's Avatar
Here's a more concise explanation :
Thermoelectric effect - Wikipedia, the free encyclopedia
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Arctic RC Memory Coolers - anyone? zoob RAM 6 April 22, 2009 02:50 PM
i7 CPU Coolers? encorp Suggestions & Feedback 10 December 8, 2008 08:04 PM
Glacialtech coolers Kayen Air Cooling 3 August 11, 2008 10:30 AM
e-Sata Coolers sircuster Air Cooling 2 June 30, 2008 01:55 PM
phase change coolers MousePotato Water Cooling 11 March 29, 2007 07:57 PM
