Old August 27, 2009, 01:00 PM
CMetaphor's Avatar
Quadfather
Originally Posted by martin_metal_88 View Post
For now I have Yateloon on my H50, I have order Scythe and Noctua to see which is best over the yate because bearing are dying:(. I think the Scythe will be the winner dead silent and good airflow, also a powerfull fan wich will not be slowed by the staic pressure of air.
Ask for more.
Going to get a SFF21F then and throttle back the speed a lil for silence, thx guys!
Old August 27, 2009, 03:39 PM
JD JD is offline
Good choice, I like mine so hopefully you like them too.
Old August 27, 2009, 06:36 PM
martin_metal_88's Avatar
I also call the big brother of the H50 from asetek, in sale this week for 99 box at NCIX, why not:P and will test it with both fan.
Maybe a review iftime is in;)
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old August 31, 2009, 01:27 PM
Ask for more.
Please post some result, H50 vs the asetek with dual 120mm rad
Old December 2, 2009, 04:32 PM
Looking at this cooler myself and would also like to see the setup. I've been reading some good reviews but everyone complains about the fan direction into the case. I understand adding the second fan in the push/pull allows you to reverse the setup such that the heat can be pushed out the back. Please post pics and results of fans. Would like to copy if all is working well.
Old December 2, 2009, 05:54 PM
Sushi Warrior's Avatar
From what I have heard the BEST fans are Akasa Apache, for H50's specifically. However, they are basically only available in Europe. As far as Canada goes, I would say Noctua 120mm fan because of the good static pressure.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Broken 120mm fan 486 Off Topic 1 July 1, 2009 09:27 AM
WTB: E8xxx cpu, s775 water block & single 120mm rad 4wdrive Buy/Sell & Trade 0 November 9, 2008 07:32 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
9800GX2 on a single 120MM rad.... Cptn Vortex Water Cooling 37 May 20, 2008 09:38 PM
120mm Fan Suggestions CMetaphor Air Cooling 16 April 14, 2008 08:16 PM
