Originally Posted by homer98 I like the i7's, planning on overclocking as well, so would it be too much heat if I had 3 components in one loop?
Is there much benefit to WC the North Bridge? or should I not include it in the loop which might save a bit of heat? |
on an X58, you could totally do the northbridge. They get pritty warm, especially when overclocking. However, you should remember that most of the boards have heatpipes linking NB/SB and the MOSFETS. This means that if you do the NB, depending on the board, you'll likely have to get MOSFET blocks too.
Heat isnt an issue, depending on your setup. Charlie3.0 can show you a double rad doing a CPU and 2xGPU without issues. The problems usually come in with restriction of flow rate. The more objects you are cooling, the harder your pump has to work to push the water around. NB/mosfet blocks are notoriously bad for restriction, due to their small chamber sizes.
