Its done, all of those useful clecos are removed and i got the bolts installed, quite happy with the visual result.
i drilled all the holes to run the tubes and power cables. ill probly put some quick disconnect for my water hoses somewhere in between my computer and the cooling box.
well all thats left is getting some 1/2" tubes, my water blocks, and the fittings.
Any suggestions on what type of fitting and the best place to get them..
ill rearrange my computer desk and ill post some more.
cheers.
-ET
