there is a tec unite on the bottum, frum the bottum of the unite to the top of the middle tray is about 3 qauters of an inch.
you wood hav 2 find sum way to properly secure the boreas if you did'nt want to use the original mounting brakit,but you wood gain very little,not worth the trouble i think.
Here is a pic i found kinda shows the bottum.
i can take a better pic if you want and i'll steady the camera better. just let me no
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
