Old August 18, 2009, 04:33 PM
element291's Avatar
Default Moving WC PC
Hey guys, I am moving on Sept 1 and last time I moved my pc (i was driving to work with it in the car) a bit of fluid leaked from the cap on the microres.
I was wondering what the best method would be for moving the pc this time around. I plan on draining most of the fluid out of the res itself, then screwing the cap back on and gently carrying my case into my car and placing it behind the seat or something to keep it steady. That way I dont have to completely drain my loop, and when I get to the new house I can just put my pc inside, pull the side off, and top up the res.
Is there any dangers in doing this? What would be the best way in your opinion.
Thanks!
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old August 18, 2009, 04:52 PM
Jackquelegs's Avatar
You need to drain all the coolant. slosh slosh slosh
Iapetos
Zephyranthes
Old August 18, 2009, 04:53 PM
Get a cap that keeps water sealed.
Old August 18, 2009, 04:56 PM
element291's Avatar
The cap has the o-ring and i had it very tight but it still somehow managed to leak that time...
Old August 18, 2009, 05:09 PM
It's your res the problem, i was moved my computer 2 time a week for 3 month and never have a leak...
Old August 18, 2009, 06:43 PM
gingerbee's Avatar
ya the res is the problem i have moved many a water cooled pc and i never drain them
Old August 18, 2009, 06:47 PM
Sagath's Avatar
This is awsome. I was just thinking about this tonight, as I move in a week from today. We have a moving company packing us etc. Everything is insured, but I still wanted to see about the safety of this.
Thanks guys :)
Old August 18, 2009, 06:50 PM
MpG's Avatar
MpG MpG is offline
You mean, you're letting a moving company handle your computer? That's just begging for trouble, if you ask me. You should at least handle your computer personally, water-cooled or not.
One red flag that I'm seeing is the full-cover block on your video card - those have some weight to them, and if the computer is being shaken and vibrated, that might put excess stress on the video card.
Old August 18, 2009, 07:09 PM
element291's Avatar
Very good point about the full cover blocks. My computer will be right behind my seat in my 2dr car with the seat back enough so the case is snug and doesn't move around. Just the sloshing of the water will pose as the problem, but I think I'm just going to take down the fluid in the res down to the barbs and screw the cap on as tight as I can without stripping it.
Should be good, only for about 3.5 hours on the crappy 401 and QEW
Old August 18, 2009, 07:40 PM
SugarJ's Avatar
Take the time to completely drain the loop. And leaktest before you start up again. How much is your mobo/cpu/gpu/ram/psu worth? And how much is the coolant you're trying to save?
That's what I thought. :) I've lost a 4870 to a leak. Ain't worth it.
PC with Zero moving parts 486 Air Cooling 23 April 29, 2009 07:18 AM
Moving to a new place, Should I take out my CPU cooler for moving? appplejack Air Cooling 5 March 10, 2009 02:44 PM
Moving to i7... S_G New Builds 5 January 6, 2009 06:19 PM
Moving a PC tom.mullie Troubleshooting 22 August 30, 2008 10:26 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 11:35 AM
