Old August 4, 2009, 03:01 PM
Default Axle182's WCed 1200 Sli
Thought id start a new thread for my build up. Sorry but I havent been as diligent with the build up pics, I only have one set of 'mock up' pics, and one with the first lines done. Last parts from my purchase spree should arrive today! Firstly though big thankyou to Daz, Brian (Zoob), Cowboy, and everyone else i purchased from and got information from. I credit this site to my whole learning experience, you guys simply rock This is my first PC build done on my own, no one there to point out my stuff ups :help:
Pics Posted lol (see ye of lil faith! lol). I cheated, the res and #2 rad didnt arrive on the long weekend, so i plumbed it up to the thermaltake pump/res to test it out. It should arrive today so ill be rebuilding it tonight in its finished config
Full specs -
AJ1
Antec 1200 Case
Intel E8400 45nm (EK Supreme LT)
XFX 780i Tri SLI (Modded fan, heatsinks)
2x EVGA 8800GTS 512's (Danger Den Full Cover on both)
2x 500gb Seagate Sata Drives (Raid 0)
6gb Mushkin PC2-6400 (Dominator Mem Fans)
1000w Corsair PS
22x Litescribe DVD Burner
Water Cooling in order-
Pump - MCP 350
VGA Blocks - 2 x Danger Den I-Ones
Rad #1 - 240 Swiftech (Push Pull)
CPU Block - EK Supreme LT
Rad #2 - 120 Swiftech (Push Pull)
Res - Primochill 3.5 bay drive Blue
Fillport - Danger Den Blue (Drops into Res)
Things left to do -
- Drain it
- Mount Res and run res lines
- Mount Fillport
- Make permanent mount for Rad #1
- Mount Rad #2
- Finish lines and fill er up :D
Ill have a few 1/2" fittings, the thermal take gear, rads etc for sale soon :D It was surely an adventure!
AJ's Gamer, Finally finished!
Win 7 64 bit / Antec 1200 / E8400 EK Supreme LT / Xfx 780i SLI / Mushkin 6Gb EM2-6400 - Corsair 3 Fan Cooler / Corsair HX 1000W / 2xSeagate Sata II - Raid 0 / 1xSeagate Sata II - Storage and backup / 2xEVGA GTX285 1Gb- SLI Ek blocks / 2x240 Swiftech Rad, Full Push-Pull / MCP355 w/ Petra Top / Micro Res / Danger Den Fillport Blue / Matrox Digital TH2G / 3xSamsung 226BW's
Old August 4, 2009, 06:50 PM
Liu Kang's Avatar
Without pics, this build simply doesn't exist... liar.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old August 4, 2009, 07:18 PM
Dazmode's Avatar
Waiting for pics
Orange Build: Final Video
HTPC Build: Final Video
Old August 4, 2009, 09:55 PM
In the first pics you can see the 60mm fan installed on the MB with sleeved wires
This is as of tonight. The Thermochill res just wouldnt pic up properly, so the pump was always starving. I fought with it for a while, and when i stood it up as 'taped' here, it worked fine plus the flow will be visible through the side window. Ill be making up a bracket to hold the res and a bracket for the front rad tomorrow night
Old August 4, 2009, 09:58 PM
hightest's Avatar
Lookin very nice.We luv are pics here at HWC.
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
Old August 4, 2009, 10:01 PM
Other updates, thankyou to the guys with your suggestions on how to remove the double sided taped backing plate from the TT CPU block. The EK didnt come with a backing plate so i left the TT one on, problem solved. So far only major worry is that when moving one of the lines (had to drain and disconnect to move the res) one of the lines still had a fair amount of water in it and its splashed on the back of the two vid cards Its plain distilled water for now, so hopefully wont hurt it too bad (fingers shall be crossed). I dried it as best i could and blew air over it with a duster can. And yes ill be getting some nuke or whatever it is you add to the dis water . Ill be doing a fair bit more work to clean it up. I doubt itll come close to any of your clean rigs, but im trying for a fairly clean install
Its on 24hr leak test now, the MCP350 is practically silent, which is why i wanted a res i could see the flow But im sure that many fans will bring the noise back a notch
Hopefully tomorrow this time, i can bring it up stairs to the office and see if itll boot for me..... first time trying to setup raid.... if anyone knows a decent tutorial for rookies, please point it out to me!! :help:.
Old August 5, 2009, 02:34 PM
stoanee's Avatar
Nice looking first build!
heatware
Old August 5, 2009, 02:44 PM
Dazmode's Avatar
I would change that 90 degree fitting with 45 degree one.
Good job!
Old August 5, 2009, 03:11 PM
Good job!
Thanks guys.
Daz i was cautious of that too, but watching the flow into the res, its seems to run fine. I was worried as the 90 bend is kinda early in my loop, and if its slowing it down it would slow the rest of the system, but it flows really nicely. If you look closely at the res, you can see the water pouring over the divider. It was running a leak test when i took the pics. So baring no leaks, its systems go tonight Say a little prayer for me wont you guys?!
Old August 5, 2009, 08:16 PM
Dazmode's Avatar
Originally Posted by axle182 View Post
I was worried as the 90 bend is kinda early in my loop...
It is not that.... black fitting is just like a sore vs. shiny chrome
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 09:40 AM
Tri SLI, Quad SLI, SLI comparisons with 9800GTS, GX2 Babrbarossa Reviews & Articles from the Web 3 March 31, 2008 02:32 PM
Good Temps for WCed PC? Infiniti Water Cooling 10 September 22, 2007 07:21 PM
