Old August 2, 2009, 06:47 PM
MrDeodorant's Avatar
Default Water cooling the P5Q northbridge
I have a P5Q Pro. My current water cooled setup doesn't direct a lot of air over my northbridge, and it gets pretty hot. I've been thinking about buying a Swiftech MCW-30 chipset cooler, but I'm leery about removing my stock cooler, because I'm not sure how critical the mosfets under the heat pipe-section are, or how I would cool them.
Does anyone have any experience with this?
Lover of Science.
Old August 2, 2009, 07:41 PM
Jackquelegs's Avatar
Watercooling solution
NCIX.com - Buy Enzotech WMST-81NP Forged Copper Mosfet Waterblock for Select ASUS Gigabyte Motherboards - WMST-81NP In Canada.
Air cooling solution
NCIX.com - Buy Enzotech MST-81 Copper Mosfet Cooler for Select ASUS Gigabyte Motherboards - MST-81 In Canada.
NCIX.com - Buy Enzotech MOS-C1 Exceptional Heat Dissipation for Integrated Mosfet Motherboards & Video Cards - MOS-C1 In Canada.
Iapetos
Zephyranthes
Old August 2, 2009, 07:43 PM
bkh2's Avatar
Possibly another reason why that block wouldn't work is that there are capacitors in the nearby vicinity. This is similar to my Asus P6T board.
The heatpipe problem is also an issue. As of yet, I have no idea how to solve it. I'll post anything I find on this subject. Just thought I'd post to let you know that I'm also having this problem. =]
Old August 2, 2009, 09:10 PM
CanadaRox's Avatar
To cool your mosfets you can get a ThermalRight HR-09 U TYPE2 for the set closer to the rear panel and a HR-09 S TYPE2 for the upper mosfets. EK-NB S-MAX and EK-NB/SB5 will work on the northbridge.
Project: Black and White
Old August 2, 2009, 09:46 PM
Dazmode's Avatar
http://www.ekwaterblocks.com/downloa...et_04-2008.pdf
This may help you.
Orange Build: Final Video
HTPC Build: Final Video
Old August 3, 2009, 05:12 AM
if it can help you guys, on my ud5 i change the cooling last week, got an hr09 s type 3 for the top mofset(fit perfect out of the box) and an hr09 u type 3 for the side mofset(i need to use some tool to mod it sinse it dont fit because the space betwin capacitor andvoltage regulator is not to large, i finaly use thermal tape to stick it in place and use a teerap(that the name i think?) to fix it)
Old August 3, 2009, 04:01 PM
That first Enzotech cooler was exactly what I was hoping to find; I'm not sure how I missed it, but that you very much for pointing it out!
Thanks to everyone else as well for advice, and showing me I'm not the only one with these concerns.
Lover of Science.
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
[FS] P5Q PRO/HD4870 512MB/water cooling loop b1lk1 Buy/Sell & Trade 6 March 28, 2009 05:53 PM
Aftermarket chipset cooling for P5Q-Pro? The MAX Air Cooling 8 January 30, 2009 07:53 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
NorthBridge water block James_8970 Water Cooling 2 November 27, 2007 07:52 PM
