Old August 1, 2009, 07:46 AM
CMetaphor's Avatar
Quadfather
Default All in one CPU water cooling
Hey all, a few questions to the owners of some of those "all in one" closed loop cpu watercoolers:
1 - Coolit Domino Owners: can the control module on the side be moved anywhere or switched sides on the unit?
2 - Other than the Domino, what would be the next best performing kit that has a low profile cpu waterblock (not like 1U/2U low profile, but short if it has an integrated pump)
thanks for the help guys/gals.
Old August 1, 2009, 10:39 AM
JD JD is offline
I think the Corsair H50 is the only other contender, and I'm not sure if that will meet your height concerns.
Old August 1, 2009, 10:49 AM
Eagle Eye's Avatar
I know Asetek has some products simliar in nature, not sure if thats what you're looking for.
NCIX.com - Buy Asetek LCLC PRE-FILLED Liquid Cooling System CPU Block Pump 240MM Radiator No Mounting Hardware - 35-101-1012200 In Canada.
NCIX.com - Buy Asetek LCLC PRE-FILLED Liquid Cooling System CPU Block Pump 120MM Radiator No Mounting Hardware - 35-101-1012103 In Canada.
Edit...now that I compared the two, looks like Asetek and Corsair where working together on this one, near identical to the 120mm version.
EE
Old August 1, 2009, 11:10 AM
CMetaphor's Avatar
Quadfather
Actually it looks like asetek is Making the corsair... but still, either seem an interesting alternative. Does anyone have either the Asetek LCLC or the Corsair 50? IF so, could you pleasue measure the height of the pump/block combo? thanks.
Old August 1, 2009, 09:05 PM
JD JD is offline
Corsair claims to have worked with Asetek to design a better head than Asetek's own unit. So in theory, the Corsair should be better.
Martin Metal has one: Corsair Hydro H50 CPU cooler
Old August 1, 2009, 09:10 PM
3.0charlie's Avatar
Try to find a Swiftech H2O-120.
Hydro-Quebec is salivating...
Old August 1, 2009, 09:17 PM
martin_metal_88's Avatar
Yep I have one what you want me to do with? there are the mesure
H : 11CM
L: 13CM
D: 5 to 7.5 depending on the fan config ( 7.5 with push pull )
These are not really precise mesure I take them in like 5 second but I have to unmount it this week to place it on my new ATCS 840 so I will be abble to mesure it again with better tape and also try it with AC5 thermal paste.
Ask if anything more is needed about the cooler.
Old August 3, 2009, 10:06 AM
CMetaphor's Avatar
Quadfather
H : 11CM
L: 13CM
So you mean its 110mm tall from the cpu? Owch.... That would be impossible to fit in The Dark. The case Im building into is a Silverstone Sugo-03, which has about 80mm or so of clearance from the cpu to the back of the PSU. Might have to go for the Domino, unless I can find the Switech kit... but I cant seem to find it anywhere? Hmmm....
Old August 3, 2009, 10:29 AM
no no no the pump is lie 5 CM tall from CPU, these mesure are only the rad and the reservoir. Has I tell I'm waiting my ATCS 840 wich should arrive on today or tomorrow to be abble to take a better mesure of everything.
Ask for more.
Old August 3, 2009, 10:34 AM
CMetaphor's Avatar
Quadfather
Ask for more.
Ahhhhh, 5cm = 50mm = well within my height requirement for that case. Do you think the tubing that exits/enters from the block/pump combo will kink if only given 3cm to turn 90 degrees? I believe one of the sides of the block was "opened" to allow the tubing to bend more easily. Could you check though martin metal? thanks.
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
[WTB] water cooling + s939 x2 cpu. upsidedown Buy/Sell & Trade 6 February 10, 2009 11:07 AM
<<FOR SALE>> CPU, GFX, RAM, HDD, Air & Water Cooling NewHall Buy/Sell & Trade 24 October 10, 2008 03:24 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
