Old July 31, 2009, 07:21 PM
bkh2's Avatar
Default Motherboard Waterblock Compatibility Issues
I'm looking to purchase this Chipset cooler (Swiftech MCW30):
NCIX.com - Buy Swiftech MCW30 Chipset Waterblock for Most AMD & Intel Motherboards 1/2IN &3/8IN Barbs - MCW30 In Canada.
I currently have this board (Asus P6T):
NCIX.com - Buy ASUS P6T X58 ATX LGA1366 DDR3 3PCI-E16 PCI-E1 2PCI CrossFire SLI SATA2 GBLAN Motherboard - P6T In Canada.
The problem is with the mounting:
At the bottom left mounting screw, there's a phat VRM and a capacitor. Also, the PCI-e lane is very close to the Northbrige cooler. Those components make me unsure of whether mounting the waterblock will be a problem, since the mounting mechanism on the waterblock is a curved do-hickie thing.
Any information on whether or not these parts are compatible with each other will be greatly appreciated.
Note: I've emailed Swiftech about compatibility and they said they don't know.
Old July 31, 2009, 08:44 PM
Dazmode's Avatar
my undertsnding is that WCw30 is for LGA755 boards.
Orange Build: Final Video
HTPC Build: Final Video
Old July 31, 2009, 09:15 PM
MpG's Avatar
MpG MpG is offline
I wouldn't expect the MCW60 to fit that board, as you're saying, there's definitely a clearance issue. There's THIS block, which is supposed to be for the board, but doesn't look like it would work unless it was a mirror-image of itself. Not sure what to think about that.
Regardless, you'd still have to do something for the voltage regulator section, since you'd be tearing up a heatpipe in the process.
IFX-14 Compatibility CORE Air Cooling 3 July 1, 2009 05:05 PM
Vista Compatibility Bullterrier Troubleshooting 7 June 16, 2009 01:30 PM
Curious about Compatibility Diego22 New Builds 8 May 27, 2009 04:31 PM
Motherboard Issues ImmaPC CPU's and Motherboards 13 December 14, 2008 12:45 AM
4 kit ram compatibility issues? AERo RAM 3 December 19, 2007 02:15 PM
