Old August 3, 2007, 02:37 PM
3.0charlie's Avatar
N'importe quand. ;)
Old August 4, 2007, 08:07 AM
Working fine now.
I did a quick OCing like 11 x 300. The CPU temps is about 10 C lower compare with the Ultra TEC. I ran 4 instances of Prime95, CPU and memory at 100% and CoreTemp is 65C after an hour.
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old August 4, 2007, 09:10 AM
lowfat's Avatar
The absolutely easiest way to get air out of a setup is adding a res, I went for 3 years with T-Lines and finally tried a res, and wow what a difference.
Old August 4, 2007, 09:33 AM
3.0charlie's Avatar
Originally Posted by francois methot View Post
Working fine now.
Though I know nothing about quads, 65C is high. What's your voltage set to in the BIOS?
Old August 5, 2007, 06:30 AM
1.4 volt. The voltage is increase each time I am not stable with Prime during the OC process.
Always hot, not matter what!
Old August 5, 2007, 06:34 AM
It took me 30 minutes of short burst and some little shaking on the tube to force the bubles to go up in the Y...
Now there is none.
Old August 5, 2007, 07:34 AM
3.0charlie's Avatar
Woa. Only 1.4V and 65C? Are you sure the block is seated properly on top of the CPU?
Old August 6, 2007, 07:17 AM
yes, the bloc is well seated. The Quad always get hot.
Maybe there is something wrong, is somebody get better CoreTemp reading at 3.3 GHz working at 100%?
  #19 (permalink)
Old August 6, 2007, 07:23 AM
3.0charlie's Avatar
Maybe there is something wrong?
Maybe, maybe not. Like I said, I don't know anything about Quads. If it does run hot, you're on the 65C limit...
any other software that can read Quad temps?
I can't remove my side panel... Slinger Troubleshooting 5 February 29, 2008 10:26 AM
What tube is this? biff Water Cooling 4 February 1, 2008 10:30 AM
Do i need to remove V-droop with the voltage dampner magictorch Troubleshooting 1 January 19, 2008 06:16 PM
Air Pressure inside of Antec P182? Falcon Water Cooling 9 December 30, 2007 10:15 PM
Gaming Laptop roundup by Inside HW Babrbarossa Reviews & Articles from the Web 0 June 13, 2007 08:37 AM
