Old July 30, 2009, 02:44 PM
kruzn4evr's Avatar
Question Need some advice on EK-FC295 blocks
Not sure if anyone has these blocks but I'm using them in a clients build and I have a question. EK says to use ceramique (non conductive) paste on the ram chips. Unfortunately I ran out and Can. Computers is out of stock, all I have is MX-2 and this Thermalright white paste but I'm pretty sure its not non-conductive. What I want to know is, could I use the pads from the stock cooler? They are thicker and I don't want to tighten the screws too much but I'm concerned about overall contact.
What would really solve my problem is if members in the Ajax/Pickering/Oshawa area has any non-conductive paste kicking around they could spare, I would REALLY appreciate it if you could PM me. I'd order some but it wouldn't be here until Tuesday and I need to get this rig out by Sat. Sunday.
Cheers and Thanks in advance
Old July 30, 2009, 05:52 PM
Dazmode's Avatar
I use MX-2 and GELID , no problems whatsoever. Is MX-2 conductive? I don't think so...
Orange Build: Final Video
HTPC Build: Final Video
Old July 30, 2009, 07:39 PM
kruzn4evr's Avatar
Now I just feel like the dumb blonde I sometimes am ...never even thought to look it up but you're right, MX-2 is non-conductive. All I can say is it was a late night early morning and thats my story and stickin' to it
Old July 30, 2009, 07:47 PM
Dazmode's Avatar
try GELID, you'll never come back.
YouTube - Artic Cooling MX-2 and GELID thermal compaunds comparison
Old July 30, 2009, 08:23 PM
MpG's Avatar
MpG MpG is offline
If you can get proper contact, MX-2 will work fine. It's actually non-conductive AND non-capacitive, so you're pretty well covered. That, and I once squirted a bunch on a motherboard by accident, and never had any problems.
Old August 8, 2009, 07:05 PM
Apollo4g's Avatar
Confirmation #2, MX-2 is non conductive....shame on you kruzn4evr
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old August 8, 2009, 07:11 PM
Jackquelegs's Avatar
Shame!
It's non-conductive due to the absence of any metal compounds.
Iapetos
Zephyranthes
Old August 8, 2009, 07:55 PM
Sushi Warrior's Avatar
Even AS5 is non-conductive...
Old August 8, 2009, 08:45 PM
AS5 is capacitive
Iapetos
Zephyranthes
Old August 9, 2009, 12:24 AM
Originally Posted by Dazmode View Post
Nice vid Daz.. .. it really pisses me off, and then at the end... you see, day and night difference... sorry just funny.. :p
Kruz sorry to threadjack my friend.. Daz would you use that Gelid stuff on vid cards only or cpu should be fine too ?
Adding blocks? Fudd Rucker Water Cooling 11 July 8, 2009 07:42 PM
Switches and Terminal Blocks sinticfury Troubleshooting 3 June 22, 2009 10:11 PM
recommend water blocks gingerbee Water Cooling 9 June 10, 2009 03:51 PM
water blocks WolfBane Water Cooling 9 April 19, 2009 06:38 PM
installing mosfet blocks. kyle_L Water Cooling 7 February 21, 2009 08:24 PM
