Old August 9, 2009, 03:51 AM
Jackquelegs's Avatar
I have both compounds, and I honestly use whichever is in the general vicinity. I've seen no differences between the two
Iapetos
Zephyranthes
Old August 9, 2009, 06:59 AM
Dazmode's Avatar
Originally Posted by miggs78 View Post
Daz would you use that Gelid stuff on vid cards only or cpu should be fine too ?
Anything will do.
I have not seen thermal compound that can be used on CPU only or vid card only....
Orange Build: Final Video
HTPC Build: Final Video
Old August 9, 2009, 08:22 AM
Sushi Warrior's Avatar
Originally Posted by Jackquelegs View Post
AS5 is capacitive
Oh yeah... woopsies.
Adding blocks? Fudd Rucker Water Cooling 11 July 8, 2009 07:42 PM
Switches and Terminal Blocks sinticfury Troubleshooting 3 June 22, 2009 10:11 PM
recommend water blocks gingerbee Water Cooling 9 June 10, 2009 03:51 PM
water blocks WolfBane Water Cooling 9 April 19, 2009 06:38 PM
installing mosfet blocks. kyle_L Water Cooling 7 February 21, 2009 07:24 PM
