Old July 27, 2009, 04:11 PM
Default Damn TT backing plate.....
OK im gona cry (or fist thru wall.... whichever comes first!) if i cant find a solution. I impatiently test fitted the Thermal take CPU block. Followed instructions which include using a foam pad with stick on it to attach it to the mainboard. Now how on earth do i remove it! Its super strong, and im freaking that i cant remove it now to attach the swiftech one when it arrives.... I knew there was a reason my father tried so desperately to make me more methodical!!!!
Any ideas guys???
AJ's Gamer, Finally finished!
Win 7 64 bit / Antec 1200 / E8400 EK Supreme LT / Xfx 780i SLI / Mushkin 6Gb EM2-6400 - Corsair 3 Fan Cooler / Corsair HX 1000W / 2xSeagate Sata II - Raid 0 / 1xSeagate Sata II - Storage and backup / 2xEVGA GTX285 1Gb- SLI Ek blocks / 2x240 Swiftech Rad, Full Push-Pull / MCP355 w/ Petra Top / Micro Res / Danger Den Fillport Blue / Matrox Digital TH2G / 3xSamsung 226BW's
Old July 27, 2009, 04:37 PM
kruzn4evr's Avatar
I had the same problem about a year ago, it really is a pain in the a$$ to remove. I used some rubbing alcohol and a few Q-tips and just dabbed it all around to help loosen up the sticky, then VERY CAREFULLY using an exacto knife blade just slowly slide it between the sticky and the board, it took a fair bit of time and alot of patience but it will come off. I learned a valuable lesson and now I buy double sided tape and only use enough to hold the plate in place. TT should be shot for thinking of a better way to use the backplate.
If you hang in there I'm sure others will have some more suggestions to help you out
Old July 27, 2009, 05:29 PM
Apollo4g's Avatar
yup that ones a killer to take off!
I had to use a razor blade and slow cut the backplate free.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old July 27, 2009, 05:39 PM
gingerbee's Avatar
blow dryer will help a lot good luck adn watch out for TT stuff ha ha just joking.
Old July 27, 2009, 05:51 PM
JD JD is offline
Either blow dry it, and then carefully pry it off with something fairly blunt (since it'll be too hot to touch) or stick it in the freezer (the whole motherboard) and leave it there for like 6h. One of those should make it easier to get off.
Old July 27, 2009, 08:54 PM
sswilson's Avatar
++ for a blow dryer on low settings to remove backplates. Just take it slow.
Old July 27, 2009, 10:19 PM
CanadaRox's Avatar
Blow dryer should do the trick. Make sure the foam is peeling away nicely. I managed to kill a motherboard by trying to remove the backplate without a blow dryer/rubbing alcohol.
Project: Black and White
Old July 28, 2009, 02:15 PM
Sadasius's Avatar
Yeah a blow dryer will definitely work and make it all nice and sticky. Will be a bitch to get all that glue off afterward. Would have to use some sort of solvent to get that glue off.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Damn it shaw! Phobia Networking 14 April 1, 2009 01:00 AM
CPU backing plate question kruzn4evr O/S's, Drivers & General Software 9 November 14, 2008 04:17 PM
Backing up a system encorp Troubleshooting 12 November 2, 2008 03:26 PM
Damn Arctic Cooling.. Infiniti Video Cards 27 September 19, 2008 10:06 PM
Damn core 2 errored Supergrover HardwareCanucks F@H Team 5 April 10, 2007 07:52 PM
