Old July 23, 2009, 11:27 AM
Jackquelegs's Avatar
Default Typhoon III
Looks like a very promising D5 top/ Reservoir. Can't wait to try it out.
So far it includes the
-Res
-Plastic Compression fittings for various sizes
-D5 Mounting kit
-LEDs
Quite awesome for a reservoir. Anyone else currently using one?
Iapetos
Zephyranthes
Old July 23, 2009, 11:37 AM
gingerbee's Avatar
let's see it action pics please. When you get some
Old July 23, 2009, 11:44 AM
Just got it today, and complaining to NCIX about a missing compression fittings
Iapetos
Zephyranthes
Old July 23, 2009, 12:39 PM
MpG's Avatar
MpG MpG is offline
The T3 really is one of those things were you stare it, think about it, then smack your head because it seems so obvious in hindsight. Kind of wish I had an excuse to try one myself.
Old July 23, 2009, 12:44 PM
JD JD is offline
Similar to the XSPC DDC dual-bay res that I want to get since I don't have a D5.
Though I really don't know why it was never thought of until just recently. It's such a logical way of doing things.
Old July 23, 2009, 01:05 PM
For sure. However it's not really compatible with HAF 932 bays, or any bays that have a 2 piece support bracket. When mounted properly, half of this thing still protrudes the case.
This is pissing my off quite badly heh
Iapetos
Zephyranthes
Old July 23, 2009, 06:06 PM
aviduser's Avatar
I would be if I had any room in my case for that thing.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old July 23, 2009, 06:13 PM
Arinoth's Avatar
That is going to purr when its all set up, looks great already
Here I am: here I remain
Old July 23, 2009, 06:37 PM
I spent a whole afternoon tweaking stuff...and found out I'm out of tubing
So far complaints
- Stock ghost compressions leak like no tomorrow
- One outlet on mine is strangely leaky, no matter what barbs.
- Bleeding it VERY difficult if you don't follow their instructions (tilt the case backwards). Very impractical since I have a rear mounted rad.
On a bright note, it looks good
Iapetos
Zephyranthes
Old July 24, 2009, 11:55 AM
have you tried teflon tape on the treads of the barbs before you install it? Wondering if that will help it seal? Although it wont look very nice on a clear res im sure.
AJ's Gamer, Finally finished!
Win 7 64 bit / Antec 1200 / E8400 EK Supreme LT / Xfx 780i SLI / Mushkin 6Gb EM2-6400 - Corsair 3 Fan Cooler / Corsair HX 1000W / 2xSeagate Sata II - Raid 0 / 1xSeagate Sata II - Storage and backup / 2xEVGA GTX285 1Gb- SLI Ek blocks / 2x240 Swiftech Rad, Full Push-Pull / MCP355 w/ Petra Top / Micro Res / Danger Den Fillport Blue / Matrox Digital TH2G / 3xSamsung 226BW's
[FS] OCZ Reaper 2x1Gb DDR2-1150, Razer Lachesis, Thermaltake Big Typhoon PanzerIV Buy/Sell & Trade 2 April 3, 2009 09:01 PM
[FS] OCZ Reaper 2x1Gb DDR2-1150, Razer Lachesis, Thermaltake Big Typhoon... PanzerIV Buy/Sell & Trade 0 February 5, 2009 01:58 AM
Big Typhoon VX & Xigmatek HDT-D1284 Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
So the Thermaltake Big Typhoon VX, eh? Babrbarossa Reviews & Articles from the Web 3 June 9, 2007 02:55 PM
