  #31 (permalink)
Old July 24, 2009, 11:27 PM
Jackquelegs's Avatar
Your spelling astonishes me
Iapetos
Zephyranthes
  #32 (permalink)
Old July 24, 2009, 11:33 PM
Chilly's Avatar
Sh]uhhh, you were much worse azat the lase meet up, :D youi were lots of druink fun at the least meet uo :D Ld :d :D LD so0 if I am drudsbnvcds v once tgats iuts fubne
I am lots of fun and so are tyouszΩzz@!!!!
  #33 (permalink)
Old July 24, 2009, 11:41 PM
ChuckleBrother's Avatar
Is it just me or do you have the tubing connecting to the same inlet/outlet sides(preventing proper flow). Maybe I'm just really tired:)
"...you play a mean banjo"
  #34 (permalink)
Old July 24, 2009, 11:43 PM
Nope, That curve of a tubing is top outlet to Radiator
CPU loop:
Top outlet > Radiator > CPU block > Top Inlet
GPU Loop:
Bottom outlet > Radiator > GPU block >Bottom inlet
Iapetos
Zephyranthes
  #35 (permalink)
Old July 25, 2009, 07:09 AM
SugarJ's Avatar
And you fill it through the front ports, correct? Which would explain your bleeding problem comment. Or I guess you could T-line one loop.
  #36 (permalink)
Old July 25, 2009, 09:03 AM
CPU loop:
GPU Loop:
I was referring to the tubing on the GPU block, unless I am highly confused are you not just running water in and straight out with the way that tubing is run? Or is it just a very badly designed block?
  #37 (permalink)
Old July 25, 2009, 01:31 PM
Im using it
  #38 (permalink)
Old July 25, 2009, 02:43 PM
Oh yeah, I needed to leave extra tubing on all leads running towards/from the Typhoon. Since I need the convenience of being able to slide the T3 forward and out for quick fixes.
It was just a bit of extra tubing
Gord: Yeah the bleeding isn't easy. I had the typhoon front face up hanging out my case to fill it. I can't tilt my case since my PA120.2 is in the back
T-line wouldn't work, I tried it. Since air doesn't actively go out through the Tee, Air pressure tends to build up in the top area before going out through one of the threads.
Iapetos
Zephyranthes
  #39 (permalink)
Old July 25, 2009, 09:53 PM
SugarJ's Avatar
Thanks for the explanation Jackie. I know what I need to know now.
  #40 (permalink)
Old July 26, 2009, 07:46 PM
Here is my unboxing video and pictures.
YouTube - Primochill Typhoon III Unboxing
[FS] OCZ Reaper 2x1Gb DDR2-1150, Razer Lachesis, Thermaltake Big Typhoon PanzerIV Buy/Sell & Trade 2 April 3, 2009 09:01 PM
[FS] OCZ Reaper 2x1Gb DDR2-1150, Razer Lachesis, Thermaltake Big Typhoon... PanzerIV Buy/Sell & Trade 0 February 5, 2009 01:58 AM
Big Typhoon VX & Xigmatek HDT-D1284 Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
So the Thermaltake Big Typhoon VX, eh? Babrbarossa Reviews & Articles from the Web 3 June 9, 2007 02:55 PM
