Old July 24, 2009, 12:33 PM
Dazmode's Avatar
Never feel for bay reservoirs... I think they look foreign to case design.
Try to use thicker o-ring for leaking outlet. Teflon is not good...
Orange Build: Final Video
HTPC Build: Final Video
Old July 24, 2009, 12:55 PM
I liked the idea as my PC will be under my desk, so the display of the water level will be nice. Ive noted that about the teflon, we used it in plumbing oil lines and works a treat, i wont use it on the pc tho :D
AJ's Gamer, Finally finished!
Win 7 64 bit / Antec 1200 / E8400 EK Supreme LT / Xfx 780i SLI / Mushkin 6Gb EM2-6400 - Corsair 3 Fan Cooler / Corsair HX 1000W / 2xSeagate Sata II - Raid 0 / 1xSeagate Sata II - Storage and backup / 2xEVGA GTX285 1Gb- SLI Ek blocks / 2x240 Swiftech Rad, Full Push-Pull / MCP355 w/ Petra Top / Micro Res / Danger Den Fillport Blue / Matrox Digital TH2G / 3xSamsung 226BW's
Old July 24, 2009, 01:11 PM
Sadasius's Avatar
I wonder how easy it is to bleed. I am also wondering if it would cause any case vibration when bolted up. Very smart design.
*edit* Doh... Okay I read the post of the leaks and it being hard to bleed. Did not see it.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old July 24, 2009, 01:28 PM
JD JD is offline
Originally Posted by Jackquelegs View Post
So far complaints
- Stock ghost compressions leak like no tomorrow
- One outlet on mine is strangely leaky, no matter what barbs.
- Bleeding it VERY difficult if you don't follow their instructions (tilt the case backwards). Very impractical since I have a rear mounted rad.
Sounds like Primochill...
Only thing I'll buy from them is tubing. I hated their normal ghost barbs since they started leaking a couple months down the road. So I'm not really surprised, and well who makes a compression fitting out of clear plastic? The have such tension on them that it needs to be metal IMO.
Old July 24, 2009, 01:52 PM
Jackquelegs's Avatar
It's not the threading that's leaking, instead it's a widely addressed problem that some barbs have too wide of a base, or too thin of an O-ring for the T3. The sockets have a indent around them apparently, so I'm waiting for more bitspower fittings which are reported to work well.
Iapetos
Zephyranthes
Old July 24, 2009, 02:00 PM
Dazmode's Avatar
The best o-rings are on Swiftech barbs.
Old July 24, 2009, 02:35 PM
Yep they don't cheap out on O-rings, but the Bitspower ones are equally as good
Iapetos
Zephyranthes
Old July 24, 2009, 03:06 PM
Actually Dazmode, I found the O-rings on the D-tek barbs were pretty thick man..
  #19 (permalink)
Old July 24, 2009, 08:12 PM
Okay finally some pics up, after I ran out of tubing yesterday. Picked up some green ones for my GPU loop
Iapetos
Zephyranthes
  #20 (permalink)
Old July 24, 2009, 08:13 PM
kruzn4evr's Avatar
For sure. However it's not really compatible with HAF 932 bays, or any bays that have a 2 piece support bracket. When mounted properly, half of this thing still protrudes the case.
This is pissing my off quite badly heh
I just got one too, it is a pain in the butt for the HAF but I just bent down the tabs (carefully) slid it in and used the 2 mounting screws on the right side and used some foam inbetween the res and case to snug it up, fits nicely and appears to be solidly in place but I won't know until I go to fill it, which won't be until next weekwhen the rest of my parts get here.
Just took a couple of quick pics of the test fitting
[FS] OCZ Reaper 2x1Gb DDR2-1150, Razer Lachesis, Thermaltake Big Typhoon PanzerIV Buy/Sell & Trade 2 April 3, 2009 09:01 PM
[FS] OCZ Reaper 2x1Gb DDR2-1150, Razer Lachesis, Thermaltake Big Typhoon... PanzerIV Buy/Sell & Trade 0 February 5, 2009 01:58 AM
Big Typhoon VX & Xigmatek HDT-D1284 Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
So the Thermaltake Big Typhoon VX, eh? Babrbarossa Reviews & Articles from the Web 3 June 9, 2007 02:55 PM
