Old July 20, 2009, 07:00 PM
Default Question on Rad sizes
I'm looking at putting together my first WC setup and had a question about available sizes for rads. I plan to use a Cooler Master ATCS 840 case and it mainly uses 230 mm fans. Although I could use a 3x 120 mm rad on top in place of the 2x 230 mm, the CFM / noise of the 230 mm fans tends to be better.
Are 230 mm (or 2x 230 mm) rads available? I've looked at all the WC manufactures I could find and haven't been able to find one.
Thanks
James
Old July 20, 2009, 07:36 PM
Dazmode's Avatar
No largest rads at the moment 140mm.
Orange Build: Final Video
HTPC Build: Final Video
Old July 20, 2009, 09:06 PM
MpG's Avatar
MpG MpG is offline
Even though the 230mm fans technically have a better air/noise ratio, that's only in an open-air situation. The fans have very low static pressure, which means they choke pretty quickly under restriction. The 120mm fans are better at pushing air through obstructions such as a radiator, so you'd actually do better to use 120mm fans if you going to mount a radiator up there.
Old July 25, 2009, 06:59 AM
Thanks for the replies - Hadn't thought about it from a static pressure point of view. I think I'll look to do a push / pull setup using fairly quiet 120mm fans and a 3x rad.
Thanks again
James
Old July 29, 2009, 06:11 PM
elwoodz's Avatar
yeah that would be a good setup
Good online place to buy sleeving equipment? & What sizes do you use? chouchou Guides & How-to's 4 June 28, 2009 12:51 AM
Setting font sizes on a large screen 3 of 7 Display Units 0 March 17, 2009 04:26 PM
T-Shirt Sizes Gav Site Announcements 22 November 17, 2008 09:10 PM
Cosmos watercooling question - top-mounted rad... Synth Water Cooling 8 July 19, 2008 12:03 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
