Old July 18, 2009, 02:36 PM
Beermaster's Avatar
Default How tight is tight?
Okay mounting the CPU block (EK Supreme) right now, and how do i know i have it screwed down enough? or too much?
I don't want to break anything, so hoping i can get some guidance on this, if pics are needed i can do that in a heartbeat
Let me know thx
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov Acer One*8gb SSD*WinXP pro
Tathar WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old July 18, 2009, 03:14 PM
Jackquelegs's Avatar
I think the manual says "tighten until you feel a light resistance"
I do it until there's about 0.5cm of space between the nut and bolt
EDIT: This is on the Supreme LT
Iapetos
Zephyranthes
Old July 18, 2009, 06:34 PM
Lpfan4ever's Avatar
The Supreme will tighten pretty far without a whole lots of resistance. Be careful, because my motherboard was flexing like crazy and there wasn't much resistance on the screws yet.
I can't talk my side panel off and measure at the moment, but it looks like my nuts (hardy har har) are under 1CM down the screw.
Originally Posted by encorp
Code:
<firebane> slightly used
Old July 18, 2009, 07:43 PM
Buy the EK backplate you lazy bums
Iapetos
Zephyranthes
Old July 18, 2009, 07:50 PM
MpG's Avatar
MpG MpG is offline
Seriously, it should be illegal to sell a waterblock without a backplate.
Old July 18, 2009, 08:10 PM
+1. I died a little inside during the week that my Ek's backplate was in the mail. So much warping
Iapetos
Zephyranthes
Mem. OC. High FSB vs Tight timings Gooses Overclocking, Tweaking and Benchmarking 1 September 3, 2008 09:31 PM
Tight Budget Overclocking! Digital_fx3 Overclocking, Tweaking and Benchmarking 18 April 27, 2008 03:52 PM
