Old July 17, 2009, 03:23 PM
Shadowmeph's Avatar
Default Do hose lengths matter ?
the hose lengths that I have a a little long does that really matter much in temps ranges?
Old July 17, 2009, 04:34 PM
gingerbee's Avatar
not really as long as you have a good pump
Old July 17, 2009, 04:50 PM
MpG's Avatar
MpG MpG is offline
All else equal, I'd rather have five extra feet of tubing over one elbow. Tubing is pretty minimal resistance to begin with, nevermind having any noticeable impact on temperatures.
Old July 17, 2009, 05:03 PM
Shadowmeph's Avatar
ok good then I won't shorten my Hoses ( that doesn't some good does it lol )
Old July 17, 2009, 05:08 PM
Sadasius's Avatar
My wife says hose size does matter! But seriously it is minimal fir an extra foot or so as long as it's not 50 feet away or something.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
RAM mistake, does it matter ? Kilauea RAM 6 June 16, 2009 09:09 PM
When Noise Doesn't Matter Soultribunal Air Cooling 0 December 8, 2008 08:40 AM
wormdrive hose clamps nikitos Water Cooling 6 June 19, 2008 11:16 PM
Case Cooling and Airflow - How much does it matter CasheKicker Air Cooling 18 March 14, 2008 09:30 AM
dose the length of warranty really matter to u? cmhyt Video Cards 7 December 17, 2007 07:57 AM
