Hi I live in
Canada,
QUÉBEC
and it come to a problem went I need some specialized piece of hardware.
Alright, let's begin!
I am planning to water cool all my MSI 790fx-gd70 motherboard: CPU, North and south bridge and voltreg... (/$%?&*!) & modding my case a little.
I'm not interested in WC my video card at the moment, simply doesn't need it.
I already own a Xspc delta v3 CPU block, with a tank/pump combo+120mm rad.
I would like to buy:
2 X xspc X2O universal chipset waterblock
1 X koolance MVR-40
3/8 in / 1/2out tubing
(uv one) & compression fitting
1 X xspc dual bay reservoir/combo 750lph pump
1 X swiftech MCR 320 radiator
(Maybe home made shroud but we will see..)
I own a HAF 932 case, so I know the Swiftech radiator will fit on the top.
What I worry the most is the 750 lph pump with the swiftech rad + 4 cooling block.
Will it perform correctly, do I need a special setup loop for that? Do I need a better pump?
I am planning to command my items from koolance, directcanada (AAhhhh thx god saving me BUCK!!!
), frozencpu and maybe sidewinder).
I would like your comment on the hardware AND the online shop too!
Thx for the advice!
