Old July 13, 2009, 06:28 PM
Cowboy's Avatar
Default Where to buy specialty fittings?
I'm looking for either swiftech F fittings from 3/8" to 1/4" like this
or 3/8" to 1/4" reduction fittings like this
Going to mod my freezone elite, and I need these fittings. I can't find them anywhere in canada. WTF
Old July 13, 2009, 06:32 PM
MpG's Avatar
MpG MpG is offline
PPC's seems to have both the F-fittings and the reducers in stock.
I'm sure there's a few reasons to NOT open up the Freezone, though. Not the least being that any sort of expansion will require adding more fluid, and I don't think those systems use plain water. Also, I don't know if the systems are capable of bleeding the way normal WC systems are, which could make it very difficult to fully fill and seal the system again afterwards.
Old July 13, 2009, 06:34 PM
Dazmode's Avatar
Linus at NCIX might help you, if he would care to order them.
Orange Build: Final Video
HTPC Build: Final Video
Old July 13, 2009, 06:38 PM
don't bother with reducing fittings like that (with barbs on both ends). just use 3/8" tubing and squeeeeze it on your 1/2" :)
heatware
Old July 13, 2009, 06:43 PM
Cowboy's Avatar
@MpG:
Thanks, but I was specifically looking for these fittings in canada so that I don't have to wait 2 weeks for shipping or pay through the nose to get them here faster. The Freezone uses 50/50 distilled water and ethylene glycol-based anti-freeze, and I would be using the fittings to put in a T-line along with my planned mod.
@Daz:
I Think I'll give Linus a try, but I still don't feel like waiting for him to order them. I feel it would be faster to just buy them from PPC.
@zoob:
The Freezone uses 1/4" tubing, and I primarily use 3/8" tubing (I have like 20 feet of UV green primochill tubing). And I tried forcing my tubing over the 1/2" barbs that I have... didn't work... hence why they're for sale.
@Everyone else:
Bottom line: My freezone is doing a great job of cooling my CPU @ stock. As soon as I Overclock my phenom 2 I have to crank up the freezone and its not only very loud but less effective than my old WC loop. Time for a mod!
Old July 13, 2009, 06:51 PM
3.0charlie's Avatar
When you tried to force the 1/2 tubing over the 3/8 fitting, did you dump the end of the tubing in boiling water for 5 seconds prior to trying it out?
Hydro-Quebec is salivating...
Old July 13, 2009, 06:54 PM
Cowboy's Avatar
No, I did not. I only wet the barb and the tubing prior to trying fruitlessly.
The primochill tubing I've got is really thick OD, so I doubt it would work.
Back on topic...
Old July 13, 2009, 06:59 PM
3.0charlie's Avatar
Then next time try it.
Like you say, back on topic. I'll now shut up.
Old July 13, 2009, 07:18 PM
gingerbee's Avatar
for sure charlie's got it that's how all my water cooled rigs are built it makes life so much easier. check you local hardware store i found one in orillia and it's great for different size fittings.
Old July 13, 2009, 07:22 PM
Cowboy's Avatar
So you use 3/8" tubing with 1/2" fittings? why?
[FS] WC fittings and other stuff... Frank Booth Buy/Sell & Trade 1 April 26, 2009 05:21 AM
Compression Fittings micul Water Cooling 5 April 18, 2009 03:21 AM
Fittings Issue JD Water Cooling 6 February 15, 2009 08:15 AM
Bitspower Fittings JD Water Cooling 10 August 14, 2008 10:29 PM
Primochill Ghost Fittings JD Water Cooling 2 August 8, 2008 08:40 PM
