Old July 13, 2009, 07:24 PM
3.0charlie's Avatar
No, you should use proper fitting diameter - I used to use 7/16 over 1/2 fittings.
But if you really want to use 3/8 over 1/2, then dump in boiling water. Perfect tight fit.
Hydro-Quebec is salivating...
Old July 13, 2009, 08:04 PM
gingerbee's Avatar
no i use 7/16 over 1/2 fittings.
Old July 14, 2009, 08:34 AM
Cowboy's Avatar
3/8" over 1/2" fittings would be a ludicrously tight fit, no?
Old July 14, 2009, 09:45 AM
3.0charlie's Avatar
Of course. But it can be done, need be.
Old July 14, 2009, 09:57 AM
gingerbee's Avatar
so true
[FS] WC fittings and other stuff... Frank Booth Buy/Sell & Trade 1 April 26, 2009 05:21 AM
Compression Fittings micul Water Cooling 5 April 18, 2009 03:21 AM
Fittings Issue JD Water Cooling 6 February 15, 2009 08:15 AM
Bitspower Fittings JD Water Cooling 10 August 14, 2008 10:29 PM
Primochill Ghost Fittings JD Water Cooling 2 August 8, 2008 08:40 PM
