Old July 10, 2009, 07:45 PM
Default New CPU Block required
So, turns out that my Apogee GTX will not work on my brand new Rampage Extreme so I need a new block. It mush have a "hollow" type of backplate.
Any suggestions? Looking for something preferablle in stock, and shipping from Canada. If anyone lives in Calgary, and has one theey would like to sell, I would trade my GTX + Cash for one (Depending)
Thanks,
Old July 10, 2009, 07:58 PM
ChuckleBrother's Avatar
What do you mean by hollow? A picture or link explaining the issue more in depth would be helpful for those of us not appraised of the issue.
"...you play a mean banjo"
Old July 10, 2009, 08:01 PM
Sorry,
Right behind the CPU Socket (On the back of the board) there is a Fujitsu Chip (I think for power conditioning) that gets in the way of a solid backplate, on some the backplates the centre is cut out,
I will grab a link quickly to the review on here (That shows it)
EDIT!!!!!!! Last set of pics at the bottom: ASUS Rampage Extreme X48 Motherboard Review
Old July 10, 2009, 08:30 PM
Supergrover's Avatar
Originally Posted by Wall86 View Post
Sorry,
I would just whip out my dremel and cut a hole myself. File the Edge then throw some C-channel molding on and call it a day.
R.I.P.
Old July 10, 2009, 08:51 PM
Jackquelegs's Avatar
NCIX.com - Buy Xigmatek ACK-I7751 Crossbow Mounting Kit for 3 Piece Heat Pipe for HDT-S963 HDT-S1283 RS-S1283 - ACXTACK-I7751 In Canada.
Iapetos
Zephyranthes
Old July 11, 2009, 11:54 PM
I ended up using my Boreas backplate, BUT I had to remove the plastic standoffs. This is good/bad as I can adjust contact pressure as I need to. Bad side is I could damage my CPU
I will just see how it turns out
Idon't believe it wrong stinger cpu water block Shadowmeph Water Cooling 9 June 8, 2009 12:40 PM
[WTB] Cpu block donkon Buy/Sell & Trade 1 May 15, 2009 09:09 AM
[WTB] CPU Water Block Lpfan4ever Buy/Sell & Trade 10 March 4, 2009 06:00 AM
Enzotech SCW-1 Sapphire CPU Block JD Water Cooling 2 November 23, 2007 10:29 PM
Magicool CPU Block Review Discussion Thread Misoprostol Water Cooling 3 August 4, 2007 03:58 PM
