Old July 10, 2009, 03:34 PM
Default Thermal tape & Waterblock Question
I just bought a used water block for my 4870X2 it didn't come with any thermal pads.I was wondering if you can use thermal tape instead?The block is a Koolance block and with the installation guide it has 2 different thicknesses of thermal pad 0.5mm and 1.0 mm.Does anybody regularly use thermal tape on their waterblocks,or will I have to continue my search for thermal pads?Thanks in advance for al you help.
Old July 10, 2009, 08:23 PM
MpG's Avatar
MpG MpG is offline
You can usually get away with it, unless the thermal tape is exceptionally sticky (might be hard to take off later on). But a lot of thermal tape is very thin, and many waterblocks assume a certain amount of clearance between it and the components on the PCB, to ensure to they get maximum block-core pressure. So you might have to double or triple layer the tape to ensure that everything else gets cooled too. It wouldn't be my first choice, but if you don't have any other options, you should be alright.
Old July 10, 2009, 09:55 PM
Apollo4g's Avatar
i would not use thermal tape, thermal tape is usually very sticky and you will have a very very hard time taking off the block later.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old July 10, 2009, 10:39 PM
Ok then can someone tell me where to find thermal pads in Canada?and not somewhere where it is $10.00 for 3.0cm X 3.0cm
Old July 10, 2009, 11:24 PM
JD JD is offline
Doubt you'll find anything in Canada...
EK TIM Pads for MOSFETS (Asus 1,2,3,3a,680i, 780i, 790i, GA X38) - 1mm Products Model: EK-TIM-MOSFETS [EK-TIM-MOSFETS] : Performance-PCs.com, ... sleeve it and they will come
EK Thermal Pad Full Cover for Blocks Products Model: EK-PAD-FULLCOVER [EK-PAD-FULLCOVER] : Performance-PCs.com, ... sleeve it and they will come
I know, not the right sizes but it's the right thickness. You'd just have to cut them into pieces to fit.
Old July 10, 2009, 11:30 PM
Apollo4g's Avatar
In the US, but its cheap and they have great shipping deal to Canada.
Thermal Pads [THERMALPADS1] : Performance-PCs.com, ... sleeve it and they will come
Thermal Pads 1.5" X 1.5" [THERMALPADS15] : Performance-PCs.com, ... sleeve it and they will come
Thermal tape for GPU mem Eldonko Video Cards 54 May 14, 2010 01:54 PM
[WTB] Thermal Tape punk_zappa Buy/Sell & Trade 0 June 28, 2009 02:15 AM
Thermal pads or tape for GTX on water. Sniper Video Cards 3 December 4, 2008 10:06 AM
Double sided thermal tape at NCIX Babrbarossa Water Cooling 10 October 31, 2008 12:06 AM
Akasa AK-TT12-80 Thermal Adhesive Tape Hardware Canucks Reviews & Articles from the Web 2 May 7, 2008 02:22 PM
