Old July 9, 2009, 08:47 AM
gingerbee's Avatar
i want one too
Old July 9, 2009, 08:55 AM
zlojack's Avatar
Originally Posted by odis172 View Post
Damn, now thats a block! pure copper... /drool
Where are they made?
Pricey?
Germany.
And they're in the higher price range, but well worth it based on the performance we've seen so far.
Old July 9, 2009, 09:28 AM
Liu Kang's Avatar
~$90USD
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old July 9, 2009, 10:11 AM
Avid6eek's Avatar
This block looks amazing. I just ordered one from Sidewinder today and should have it tomorow. I hope to actually be using in soon. It will be replacing my Apogee GTZ.
Old July 9, 2009, 11:39 AM
Apollo4g's Avatar
Originally Posted by zlojack View Post
Sweet. I've had mine sitting in a box for a while now
I finally got my MM Horizon, so I'll be putting the build together soon!
I'm going to nickel-plate mine
Where do you plan to nickel plate yours?
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old July 9, 2009, 12:35 PM
zlojack's Avatar
Sun Polishing & Plating Co. Ltd.
Probably going there.
Old July 9, 2009, 01:32 PM
steers's Avatar
I see that nickel plating is something that's done quite commonly to this block. Why exactly is that? Does it help with corrosion? Improve performance?
Old July 9, 2009, 02:04 PM
MpG's Avatar
MpG MpG is offline
It's entirely cosmetic. But since most waterblocks use acetal or acrylic for the visible parts, plating isn't really an option. The HK just happens to be a prime candidate for it.
  #19 (permalink)
Old July 9, 2009, 02:05 PM
Apollo4g's Avatar
It keeps the copper from oxidizing but its mainly for aesthetics.
Nice zlojack, any idea how much they are charging?
Also you giving it in yourself or sending it by mail to them?
  #20 (permalink)
Old July 9, 2009, 04:47 PM
Dazmode's Avatar
Hmmm tempting...
Orange Build: Final Video
HTPC Build: Final Video
