My case is really cramped with watercooling gear, and my 220 radiator is basically leaning against my hard drive bays and my 4870x2. I spent a bit of time in Google SketchUp trying to get a general idea of what it would look like. Any input/suggestions would be nice. I know there's no fan mount holes, but those would drive me insane trying to sketch up.
The whole box.
The front, where the fans/radiator would mount.
The back, basic exhaust.
The side where tubing would enter/exit, just a rough guess of where they should be.
And the inside. I want to keep the tubing that would link the two radiators internal, hence the hole there.
This would be a project that would take all summer as I lack basically all tools that I would need for this project. I was wondering if anybody could also suggest some building material specifics that would work best for this (type/size of wood, etc)
