Old July 3, 2009, 08:22 AM
Cowboy's Avatar
Default Time for Mtec?
I was thinking of selling all of my WC gear and buying one of these:
NCIX.com - Buy Coolit Systems Boreas 12 Tec Chiller W/MTEC Control Center Plumbed for Single CPU - BOR1C In Canada.
I've got a swiftech gtz, 2x 120.1 rads, 1x 120.2 rad, mcp355 w/ xspc top, mcw30 chipset block, mcw60 gpu block, barbs for everything, 20 ft of primochill tubing for everything
what do you guys think? would it be worth the trouble?
Old July 3, 2009, 08:24 AM
3.0charlie's Avatar
The Boreas is one heck of a unit, but is plumbed for the CPU only. You`d still need a small loop for your NB and GPU.
Hydro-Quebec is salivating...
Old July 3, 2009, 08:42 AM
Cowboy's Avatar
how would I go about doing that?
Old July 3, 2009, 08:48 AM
3.0charlie's Avatar
Plumb the Boreas? It's a sealed unit, only CoolIt can re-plumb. You could use the Boreas for the CPU as intended, but you'd need a small loop just for the NB and the GPU.
Old July 3, 2009, 08:50 AM
Cowboy's Avatar
Hmmm, That seems like it would be pretty costly.
But would it be worth it to ditch my WC gear in favour of this?
Old July 3, 2009, 09:03 AM
3.0charlie's Avatar
Can you oc your Quad further? Is it temp limited? If yes, then the Boreas will be useful. If not, then stick the WC setup.
Old July 3, 2009, 09:11 AM
Cowboy's Avatar
Well, I have not tried going over 1.55v on the chip, So i suppose I should try it out and see what kind of OC i get.
So far, its not very stable and runs @ 38C idle (according to hwmonitor) and 3dmark06 crashes at anything above 3.6 ghz
I would also like to include the koolance 4870/4890 full cover block into the boreas loop, would it be possible with custom plumbing and 1/4" barbs?
I want better a OC
Old July 3, 2009, 09:16 AM
3.0charlie's Avatar
You can't add blocks to any CoolIt products by yourself. They use crimps instead of clamps that can't be re-used. Only CoolIt can do it, for a premium (see Cmetaphor's Behemoth thread).
Old July 3, 2009, 09:22 AM
Cowboy's Avatar
yeah, i'm familiar. although it doesnt post a price for the mods.
So how much could I get for all my WC gear? say i include the koolance block and go back to air cooling for the gpu and NB.
Old July 3, 2009, 09:25 AM
CMetaphor's Avatar
Quadfather
Their barbs arent changeable either, just FYI. Modding the two freezone elites directly via coolit cost about $200, tax and shipping in - which i found to be more than reasonable considering that a decent waterblock for a CPU can cost upwards of $60 or more, and I had two blocks added.
Ah...Time for a new 32' LCD TV :) jcmaz Display Units 23 May 19, 2009 10:58 AM
CoolIT Boreas MTEC Chassis Review Comment Thread SKYMTL Water Cooling 49 December 6, 2008 12:25 PM
It's time to upgrade... 3.0charlie New Builds 9 July 4, 2008 07:43 PM
FS: CoolIT Freezone Elite /w MTEC Controller ChuckleBrother Buy/Sell & Trade 0 May 18, 2008 04:05 PM
