Old June 28, 2009, 07:53 PM
CORE's Avatar
TechWiki Moderator
Default Water Cooling Kit Question
Hi guys,
I'm a newbie in watercooling so I decided what if I'll just buy a WC kit. I have in mind of buying Noctua NH-U12P w/ a scythe slipstream 110cfm fan but a friend suggested to check the CoolIT Domino. So I'm asking you guys if this CoolIT Domino is good CPU cooler compared to the noctua and fan combo I'm thinking.
Thanks
Old June 28, 2009, 07:54 PM
3.0charlie's Avatar
A Domino for your Quad? I've tried that exact setup for a customer, which wanted a low-noise solution. It worked, but if you intend to oc that Quad, forget about it...
Old June 28, 2009, 08:02 PM
CORE's Avatar
TechWiki Moderator
Well what if at full max speed of the fan. I dont mind the noise.
Old June 28, 2009, 08:04 PM
3.0charlie's Avatar
Negative. Tried it.
Old June 28, 2009, 08:12 PM
CORE's Avatar
TechWiki Moderator
I see. Oh well then Good thing I asked. So by negative you mean the Noctua setup will outperform the Domino?
Thanks for fast input 3.0 Charlie
Old June 28, 2009, 08:13 PM
Beermaster's Avatar
Honestly i would just try going with a build it yourself, i am doing that now for the first time, and man am i learning alot
these forums are really good for the help, and i have to say Dazmode on the forums here has a online store that has everything you need, and the prices where not that bad at all.
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov – Acer One*8gb SSD*WinXP pro
Tathar – WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old June 28, 2009, 08:14 PM
3.0charlie's Avatar
You bet.
Old June 28, 2009, 08:17 PM
Supergrover's Avatar
+1 for DIY, you'll end up with much better components and you will be learning.
Come to the Darkside.
R.I.P.
Old June 28, 2009, 08:19 PM
Beermaster's Avatar
As well as enjoying the build process, now i have to OC it, cause damn if i am going to go do all this and leave it stock lol
Old June 28, 2009, 08:23 PM
CORE's Avatar
TechWiki Moderator
stay away ebyllll Well as much as I wanted to go a DIY WC setup, I still have insufficient funding for a full one. *thats the only thing hindering me from going to darkside*
PS
Thanks for your good feedback.
Water cooling fluid question tzetsin Overclocking, Tweaking and Benchmarking 47 February 18, 2008 04:13 PM
Water cooling question Infiniti Water Cooling 11 December 26, 2007 11:11 AM
Reviewer Tryouts: NCIx Essentials 120 Water cooling kit 3.0charlie Member Reviews 11 November 15, 2007 01:37 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
Techgage reviews Zalman Reserator 2 fanless water cooling kit Supergrover Reviews & Articles from the Web 0 February 15, 2007 09:57 AM
