Old June 28, 2009, 08:28 PM
FiXT's Avatar
Hall of Fame
Really? Domino + Quad = Fail?
I'ved used it before on a few 4cores and never had much an an issue. Granted, they weren't OC'd. I figured Coolit had addressed the quad core overclocking thing with the PURE when they released the Domino :S
Bust. Heard nothing but good things about it too.
Old June 29, 2009, 04:00 AM
Jackquelegs's Avatar
Domino + Quad = meh
It's still a low level watercooling system. I don't think it's designed to handle the output of an overclocked quad. More or less aimed at people looking for a quiet cooling solution.
Ditto on the DIY. Come to the dark side, we have cookies and UV.
Honestly if you buy your parts second hand (through a trustworthy person of course), the price of a full WC isn't that bad. The only part I'd buy new is the pump.
I've heard good things about the performance, and doesn't have the PURE bubble/pump failure problem. However I have heard horror stories about the fragility of the barbs on some Dominoes.
bit-tech.net | Review - CoolIT Domino ALC
Knowing Coolit, they probably addressed this.
Iapetos
Zephyranthes
Old June 29, 2009, 05:03 AM
3.0charlie's Avatar
Stock Q9550, Domino's fine and dandy. Quiet too, even under full load.
Oc'ed Q9550 to 3.0? Forget the Domino.
CORE, as Jackie mentionned I would seriously consider used parts from the Forum members (even the pump ;)) to assemble your first WC loop. With the parts turn-over we have here, you should not have a problem finding all parts for low cost.
Hydro-Quebec is salivating...
Old June 29, 2009, 05:13 AM
CORE's Avatar
Thanks to all the guys who gave their opinions.
Water cooling fluid question tzetsin Overclocking, Tweaking and Benchmarking 47 February 18, 2008 05:13 PM
Water cooling question Infiniti Water Cooling 11 December 26, 2007 12:11 PM
Reviewer Tryouts: NCIx Essentials 120 Water cooling kit 3.0charlie Member Reviews 11 November 15, 2007 02:37 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Techgage reviews Zalman Reserator 2 fanless water cooling kit Supergrover Reviews & Articles from the Web 0 February 15, 2007 10:57 AM
