<~----> Enough Cooling? - Hardware Canucks
Old June 24, 2009, 12:23 PM
Default Enough Cooling?
Quick question would a Swiftech MCR-320 be enough for a i7-920 and a 4870X2 Loop as follows MCR320->Cpu->4870X2->Res-> pump.I am looking to moving to i7 setup but I just need to figure out the cooling issues.I would be overclocking the CPU but not the 4870X2.
Old June 24, 2009, 12:53 PM
Sadasius's Avatar
If your allergic to fan noise it won't be. That 4870X2 throws a good deal of heat and so does the i7 when you overclock keeping the HT on. You would need really good fans in push/pull.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 24, 2009, 12:57 PM
I have some low speed yate loons I would probabaly use.
Old June 24, 2009, 01:00 PM
Sadasius's Avatar
That will not do unless you overclock nothing.
Code:
Old June 24, 2009, 01:18 PM
That 4870X2 is hot,but a great card.Might have to go back to team green.I find 4870X2 is just too loud at full load.
Old June 24, 2009, 01:38 PM
SugarJ's Avatar
I've got a 920 and a GTX285 on a MCR320 with 6 low-speed YL's on it, and it's borderline.
Old June 24, 2009, 02:26 PM
Dazmode's Avatar
I'd rather have two loops or at least have better rad then cheapest model on market. It's like you buying kick a$$ sport car, but putting cheap rubber on it.
Orange Build: Final Video
HTPC Build: Final Video
Old June 24, 2009, 02:31 PM
JD JD is online now
Might want to consider the XSPC RX360. I think it should be able to cope with the heat load assuming you run 6 Yates in push/pull.
Old June 24, 2009, 03:12 PM
I have a MCR-220 will probabaly just get either another one or maybe a MCR-320.I have a full size Rocketfish case so space is not really an issue,but I guess I will just have to do a re-design to get it all setup and looking clean again.Just when I think I'm done,Modding just pulls me back in!
Old June 24, 2009, 03:21 PM
Dazmode's Avatar
Yep, that is more like it. I had single CPU on Feser 360 and it was a breeze, switched to MCR220 for comparison and it's barely handled the same set up. So, two radiators will be what you want.
NB Cooling - What would you do? biff Water Cooling 18 April 21, 2008 08:48 AM
NB Cooling.. Infiniti Water Cooling 7 April 15, 2008 06:36 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
Cooling NB jnliten CPU's and Motherboards 6 March 29, 2008 06:31 PM
How is my cooling? mattydies Water Cooling 6 August 9, 2007 08:12 AM
