Old June 24, 2009, 03:32 PM
Sadasius's Avatar
2 rads are defnitely better then one. With a RocketFish yeah I would use the MCR 320 along with the 220 in there. Then you could use those low rpm yates because you made up the difference with rad area.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 26, 2009, 03:06 PM
Is it possible to run both those rads on one pump?
Old June 26, 2009, 03:11 PM
Sadasius's Avatar
Of course you can. Flow might suffer some but it can do it easily.
Code:
Old June 26, 2009, 03:13 PM
Dazmode's Avatar
Absolutely.
Orange Build: Final Video
HTPC Build: Final Video
Old June 26, 2009, 03:17 PM
That's good news,now I just have to find a used MCR-320.
NB Cooling - What would you do? biff Water Cooling 18 April 21, 2008 08:48 AM
NB Cooling.. Infiniti Water Cooling 7 April 15, 2008 06:36 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
Cooling NB jnliten CPU's and Motherboards 6 March 29, 2008 06:31 PM
How is my cooling? mattydies Water Cooling 6 August 9, 2007 08:12 AM
