Old June 22, 2009, 01:41 PM
Default Silicone?
I was wondering why nobody seems to use silicone tubing? It seems to be really flexible and seemingly widely available so i was just wondering if its because of its milky colour or is it something else? Just wanted to ask because im considering going for silicone.
Old June 22, 2009, 01:48 PM
Sadasius's Avatar
I used to have some of the older Primochill stuff which I think was silicone because it was pretty damn soft and kinda sticky. Dust collected on it like crazy and was hard to wipe off. Not exactly the best tubing out there. Heck I am using it during the filter test. That is what is connected to the filter in the other thread.
Black Phoenix CPU-Z Validation
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Silicone or Plumbers tape... Dr_BenD_over Water Cooling 16 November 1, 2008 09:28 AM
