Old June 22, 2009, 03:34 AM
Jackquelegs's Avatar
Default RAAGE @ GTZ
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Yeah I pulled a few hair out with my GTZ a few weeks ago. Currently waiting for my EK Supreme LT to arrive. Hoping that it'll improve the temps.
This GTZ was able to keep the Q6600 at 1.57v at bay under 60C. Now it can't even handle a puny Q9450 at 1.25v. Load temps on this guy goes over 62C. THESE ARE IDLE TEMPS
Probably will take it out for a deep inspection to see if the pin matrix is clogged.
Tried remounting a few times, no dice. Any suggestions?
Iapetos
Zephyranthes
Old June 22, 2009, 04:01 AM
gingerbee's Avatar
sorry i just don't see what the problem is load of 62 is fine ( and the gtz blocks do get clogged pretty easy i clean mine every 6 months)
Old June 22, 2009, 07:20 AM
MpG's Avatar
MpG MpG is offline
Yeah, I'll grant that your temps seem abnormally high for a 45nm CPU at those clocks. Just to cover the obvious points:
-Check for clogging?
-What's the thermal paste print look like?
-Abnormally high room temperatures?
-Got the inlet and outlet correct on the block?
-Did you change your fan configuration to something odd (say, all intake or all exhaust) that would muck up the radiator's ability to keep air moving through it? Have the liquid suddenly been getting abnormally warm?
-If the pump has an rpm sensor, are the rpm numbers good?
Old June 22, 2009, 02:01 PM
-Will do
-Thermal Paste print looks normal, good coverage
-room temp is low
-all correct
-no changes from the Q6600 to Q9450, just popped a new CPU in
-Pump has the same flow as before, I can see it from my TO res
Thanks for the suggestions. I'm getting rid of this block anyways, so I'm gonna pop it open and check.
Iapetos
Zephyranthes
Old June 22, 2009, 02:21 PM
Sadasius's Avatar
I would check to see if there is a difference in height with the IHS. The GTZ can only go so far and if you lap it you will lose even more clamping force. So if the Q6600 is slightly thicker it may have had more clamping force then the Q9450.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 22, 2009, 02:23 PM
Yep, that's the issue with mounting pressure as well.
I was adjusting the mounting arms of the GTZ to get more out of it
Iapetos
Zephyranthes
Old June 22, 2009, 03:05 PM
SugarJ's Avatar
Jackie, if you've ever run any colored fluid through it, take it apart and clean it. They all seem to leave some gunk on the blocks. It's very easy to take apart, if you have the correct sized Allan key.
Old June 22, 2009, 03:24 PM
No one needs Allen keys when I have a Pipboy3000.
Yeah that's the sad part, I use Feser view dye, and I can put 10$ on the fact that it clogged some pins.
Time to buy some 7 up
Iapetos
Zephyranthes
[WTB] Swiftech GTZ 775 mount Jackquelegs Buy/Sell & Trade 4 April 29, 2009 08:08 PM
GTZ LGA1366 Adapter SugarJ Water Cooling 7 February 13, 2009 08:47 AM
Where the $%^$ is my GTZ 1366 adapter?!? Babrbarossa Water Cooling 83 January 31, 2009 12:15 PM
HWC, do you have an Apogee GTZ yet? tfran Water Cooling 14 August 19, 2008 11:47 PM
New Block coming... Apogee GTZ MpG Water Cooling 1 August 4, 2008 02:10 PM
