Old July 14, 2007, 11:01 PM
Somed00d's Avatar
Default MCW30 and DFI P965-s nightmare - pics
Ok so i read somewhere the Swiftech MCW30 works on the dfi p965-s chipset.. well it was quite the nightmare. for my first watercooling effort it didn't go without a hitch lol.
the DFI chipset only has 2 loops to hold it down. as you may or may not know many intel chipsets have 4 loops. if you only use the two loops the pressure from the tubing on the waterblock pulls it off the chip.. almost put the stock hs back on.. anyhow to make a long story short i "Made" my own second set of loops...
will follow up with my build pics.. just a temporary install until i get my next case.. perhaps antec 900..
just had to vent lol..
ok here is a pic.. sorry its blurry.. camera was set to infinity.. next time i open the case i will take a good pic..
you can see the left intel hook and the right is actually a standoff with a small metal piece with two holes in it, one for a screw and one to hook onto. the other end of the mount hooks onto the bottom of my waterblock, the apogee gt happens to have a hole in the perfect spot.
ALSO: another area of concern. the manual says you can take off the mounting brackets and use the supplied screws to hold the block together. well the screws barely grab the threads so i pulled out the first thread. the washers you see on the block are there because i used longer screws.
here is before pic.
here is a finished pic. (getting a little better at wire managment)
Q6600 G0 @ 3.2ghz (965 chipset holding me back)
DFI Infinity P965-S
Gigabyte Geforce 8500GT
Buffalo Firestix FSX800D2C-K2G 2X1GB PC2-6400 CL5
OCZ XTC Active Memory Cooler
Seagate Barracuda 250GB SATA2
MCE Wireless Keyboard / Remote
Logitech X-530 Speakers
Swiftech H20-220 Water kit
Swiftech MCW30 NB Cooling
OCZ PowerStream 600W
Old July 14, 2007, 11:08 PM
Patriote's Avatar
Can't post a thread like that without pics!
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old July 15, 2007, 08:00 AM
Somed00d's Avatar
have pics but no usb wire right now lol..
DFI Infinity P965-S
Old July 15, 2007, 08:20 AM
Supergrover's Avatar
Yeah, your a tease
R.I.P.
Dfi P965-S Dark and Q6600 Overclocking keenan CPU's and Motherboards 2 September 23, 2007 03:16 PM
Dfi P965-S CL7 in bios...? keenan CPU's and Motherboards 6 August 12, 2007 07:29 AM
Please post your DFI P965-S Dark Timings keenan CPU's and Motherboards 8 August 1, 2007 11:20 AM
DFI Infinity P965-S Dark keenan CPU's and Motherboards 10 July 26, 2007 11:30 AM
