Old June 18, 2009, 07:27 PM
ebdoradz's Avatar
Default sapphire 4830
since i have sold all my laying parts i have decide to bought myself a better video card then my X1950XT
i went with a Sapphire 4830, i dont game alot but i use to play some BF2 or RA/
NCIX.com - Buy Sapphire Radeon HD 4830 575MHZ 512MB 1.8GHZ GDDR3 HDMI DVI TV-OUT PCI-E Video Card - 11147-06-20R In Canada.
my question is, that sucker dont come with heatsink on mem chip, my current rig is watercooled, so the 4830 will be too,
do i need to put small heatsink on them?? or i should leave them the way they came?
i might try a bit of OC but nut that much
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old June 18, 2009, 10:08 PM
Eagle Eye's Avatar
The actual design of the heatsink forces air over the ram and core. If you intend on overclocking the memory it will most certainly help and ensure the life of the memory/GPU. Without proper heatsinks those chips would get pretty toasty.
EE
Old June 18, 2009, 11:35 PM
MpG's Avatar
MpG MpG is offline
The card's memory is fairly mildly clocked, so it's likely that you could get away with anything on the chips normally. But since you're putting it on water, I'd want to stick something on the chips, just to be on the safe side. Memory chips can usually take a fair bit of heat before anything goes wrong, but it would give you that extra bit of insurance.
NVIDIA 8800GT/9800GT/GTS250 or ATI 4830/4850 geokilla Video Cards 14 June 22, 2009 09:53 PM
HIS Radeon 4830 512MB BALISTX Video Cards 4 November 5, 2008 06:58 AM
ASUS over Sapphire!? Need help! Caldezar Video Cards 10 September 4, 2008 09:12 PM
Sapphire 4870 X2 , ok? Jim Video Cards 12 August 26, 2008 02:33 PM
