Old June 17, 2009, 04:25 PM
Default Fluid Expriment
I have a question about watercooling fluid. I currently have a Feser One UV Blue bottle of coolant and I am thinking about buying a Ferser One UV Red bottle from this guy on here and I was wondering if you guys think it will be bad for the system, I just want a nice purple UV. I am pretty sure it wont harm anything because all thats different is the colour. If i get some positive feedback. Thats what I plan on doing. Will post pics. Thanks!
-Sintic
Old June 17, 2009, 04:41 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by DazMode
2. Feser One UV Coolant
DON'Ts:
  • Do not mix Feser Fluids of different colors they will react.
Doesn't sound recommended. Some brands you can, but not all.
Edit: Whoops, copied the wrong line from the link.
Old June 17, 2009, 04:43 PM
Its not a dye its like basically im getting a second bottle but in red. but alright, saves me $20 xD
Old June 17, 2009, 06:34 PM
Dazmode's Avatar
PLEASE DO NOT !!!
Orange Build: Final Video
HTPC Build: Final Video
Old June 18, 2009, 04:37 AM
gingerbee's Avatar
or do and watch your machine blow up i would not do this.( different color pigment could mix and solidify in some funny spot's that's just a theory so do what you want)
Old June 18, 2009, 08:19 AM
JD JD is offline
If you want purple, buy the Feser One Black. I hear it's more purple than black, but a rather dark purple.
Old June 18, 2009, 10:35 AM
Dazmode's Avatar
Let me be clear here: You can not mix Feser with anything, except Feser of the same color.
Consider this as official warning.
If you like stay witrh Feser fluid, there is Purple version of it.
Old June 18, 2009, 12:01 PM
SugarJ's Avatar
Stay away from those Dye Bombs!! The dye separates out and leaves crap all over your blocks. I'll post a pic when I get home, I used that exact dye CB linked. It's junk. I've had no problems with the couple of premixed fluids I've tried, but honestly, you're better off with distilled and colored tubing.
Best fluid for watercooling? magictorch Water Cooling 32 August 20, 2013 07:57 PM
Volume of fluid... 4DoorGTZ Water Cooling 8 January 19, 2009 10:20 AM
Fluid XP+ Blood Red SugarJ Water Cooling 7 September 11, 2008 03:27 PM
Cooling Fluid...BLUE? frosty Water Cooling 7 June 30, 2008 01:21 PM
Overclock3D on Fluid XP+ HP watercooling fluid Supergrover Reviews & Articles from the Web 0 January 15, 2007 06:08 PM
