Old June 17, 2009, 02:05 PM
Cowboy's Avatar
Default t-line questions
hey, can a y-fitting be used in the place of a t-fitting?
reason I ask is because I have a couple y-fittings around and a t-fitting would cost like 15 bucks after shipping which is really a lot.
Old June 17, 2009, 02:11 PM
MpG's Avatar
MpG MpG is offline
As long as air bubbles can go up the line, letting you bleed the system, it'll work fine. But given the odd angle, that can be tough sometimes. Worst case scenario, you could wind up spending a day or two just waiting for the system to bleed.
Old June 17, 2009, 02:32 PM
Cowboy's Avatar
I tested it in my sink and it looks like it doesnt matter which end I use, flow remains the same. I'll just wing it with a y-fitting.
Old June 20, 2009, 01:42 AM
i used it and it works but it is harder than T because of angel
Old June 20, 2009, 09:30 AM
Cowboy's Avatar
k thanks.
Water line broke and then anouther line broke muse108dc Off Topic 3 March 28, 2009 07:34 AM
[FS] top of the line I7 Setup Table21 Buy/Sell & Trade 24 February 6, 2009 03:42 PM
Leak in T-line Phobia Water Cooling 17 June 9, 2008 04:37 PM
T-line with temp probe flclisgreat Water Cooling 7 May 10, 2008 11:30 AM
PS3 line ups? Misoprostol Gaming 4 November 22, 2006 11:20 PM
