Old June 18, 2009, 08:14 AM
Dazmode's Avatar
What is good place to buy metal cutting tools? Canadian Tire and Home Depot has quite poor selection.
I need to punch 120mm hole for the third fan at the bottom of the case.
Orange Build: Final Video
HTPC Build: Final Video
Old June 18, 2009, 01:52 PM
gingerbee's Avatar
sorry i would use home depot i guess any hardware store you can get to
Old June 18, 2009, 02:18 PM
Sadasius's Avatar
I used my trusty ol Dremel from Canadian Tire. But what I would recommend if you can find one is a 120mm hole saw that attach's to a drill if you can find one. They work much better.
Here some examples-->TCT Hole Saws
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 18, 2009, 02:45 PM
Dazmode's Avatar
Yes, just got one 102mm. Perfect for fan drilling!
Just spend $171 at Canadian Tire on dremels and riverts. But I set for life now...
Old June 18, 2009, 07:28 PM
Dazmode's Avatar
I removed drives cage and make a hole for third fan. It will be workable solution if I gave up SLI as second card basically lie down on radiator. I'll update pictures tomorrow.
The best eye-sore you'll ever play! bojangles Off Topic 20 January 23, 2009 07:06 PM
Eagle Eye's new Intel Rig Eagle Eye Case Mods, Worklog & Gallery 33 November 26, 2008 08:40 AM
Eagle Eye's new toys Eagle Eye Case Mods, Worklog & Gallery 19 November 6, 2008 09:38 AM
Question for Eagle eye. upcoast604 Video Cards 4 October 26, 2008 08:37 PM
Eagle Eye is jumping Ship Eagle Eye New Builds 8 September 5, 2008 08:55 PM
