  #21 (permalink)
Old October 17, 2010, 07:20 PM
chubaka's Avatar
Your local art store should carry them. But I got mine from beadfx.
Beadfx Sterling Wire
Scroll down to fine wire(99.9 % silver) and get the 0.8mm ones. They cost only $2.25 per foot +5.95 flat rate shipping.
  #22 (permalink)
Old October 17, 2010, 07:41 PM
CTA's Avatar
CTA CTA is offline
imp13009 .8mm x a foot = $2.25
imp16758. 2mm x a foot = $2.25
they are pretty same except thin... so i will pick 2mm... is it acceptable?
btw i dont know if we have a decent art store in bc :? you know i dont like hunting ;p
  #23 (permalink)
Old October 17, 2010, 07:48 PM
chubaka's Avatar
That is $2.25 per inch not foot... if you get the .8mm you can fold it in half to get 1.6mm(~2mm) and its still cheaper...
Have you tried the newly opened Michael's?
  #24 (permalink)
Old October 17, 2010, 08:05 PM
Lpfan4ever's Avatar
Here's the one I bought. Was originally gonna go with 20GA, but decided to go for 16GA due to how cheap it was. They've got A LOT of different gauges and lengths. Make sure you get .999 or 99.9% pure silver.
1 Ft .999 Fine Silver 16 Gauge Round Wire ~ 999 16 GA on eBay.ca (item 160405878639 end time 15-Nov-10 11:32:01 EST)
Originally Posted by encorp
Code:
<firebane> slightly used
  #25 (permalink)
Old October 17, 2010, 08:31 PM
CTA's Avatar
CTA CTA is offline
chubaka
now i am confused... it never said inch... just "foot" = a foot = 12inch... right?
.8mm or 2mm... they are still at same price... o_O?
do you mean this Michaels Stores ? if so then no... and i dont find it there... but i can visit that store tomorrow... or so... thanks tho...
and.. thank you for link... i just cant find that one... can you please tell me how it is when it arrives...
  #26 (permalink)
Old October 17, 2010, 08:50 PM
KaptCrunch's Avatar
yo save on shipping try local welding supply shop ....brazing/filler, pure silver
  #27 (permalink)
Old October 17, 2010, 08:56 PM
chubaka's Avatar
chubaka
the 2mm is 2.25 per INCH, the 0.8mm is 2.25 per FOOT. Its not the same. I am still referig to beadfx.
  #28 (permalink)
Old October 17, 2010, 09:03 PM
CTA's Avatar
CTA CTA is offline
ok you are correct... i need to go to see the eye doctor...
and i dont know that welding supply shop do carry pure silver... thanks again...
  #29 (permalink)
Old October 27, 2010, 09:13 AM
Lpfan4ever's Avatar
I got my silver rod a couple days ago from the site I linked to a few posts ago, if anybody is still looking. It got here decently fast, I guess normal shipping from US->CA, and they sent me about an inch extra which was nice.
Code:
  #30 (permalink)
Old October 27, 2010, 10:46 AM
CTA's Avatar
CTA CTA is offline
it does look great...
i still cant find it in lower mainland... so i will need to order it online... but not right now... because i will be away for victoria next week... maybe i can find it at victoria... >.>;
Silver Coils Wall86 Water Cooling 13 April 29, 2009 10:55 PM
Silver as a biocide Apollo4g Water Cooling 23 November 28, 2008 11:00 PM
Silver-Zinc batteries muse108dc Rumor Mill 1 August 29, 2008 03:51 AM
Prof. Dr. Silver is now folding too! Prof. Dr. Silver HardwareCanucks F@H Team 6 July 24, 2008 09:10 AM
