  #41 (permalink)
Old July 19, 2009, 04:37 PM
eunoia's Avatar
Thanks Martin, this is another way to set it up I hadn't considered.
  #42 (permalink)
Old July 19, 2009, 07:45 PM
martin_metal_88's Avatar
Idle temp is 24 degree with 19 in room ( note that there is 68 degree card just under ) and full load have never go up 51. I have to test it more because these are the temp I have at 3.8 but only do 3 or 4 test so I can't really tell you the truth but now it is oustanding my vendetta 2 for sure.
Ask for more if you want to know about the cooler;)
  #43 (permalink)
Old July 19, 2009, 09:24 PM
JD JD is offline
Mind running LinX for like 10 minutes and then seeing what the temperatures are with CoreTemp/RealTemp?
I'm curious because I might suggest it to my brother to get so he/I can overclock his E6600.
  #44 (permalink)
Old July 20, 2009, 11:14 AM
Ok I take note for Linx, I will do it after dinenr and post stock + 3.8 OC onmy Q9550. should be here in about an hour.
Ask for more
  #45 (permalink)
Old July 20, 2009, 12:46 PM
So as some ask me to do;) there are the first result I have to post from my H50 cooler.
Don't take this as final or buying avdise because they are not final test, only afternoon test when some time to waste.
Testing! , So the cooler it self, Corsair Hydro H50 in Push/Pull config with dual Yate loon 120mm with the corsair thermal pasta, I haven't used my Arctic Silver for this one. I will later.
CPU : Q9550 stock and 3.8 for OC test
MBO: Gigabyte Ep45-UD3P bios F7
VGA: Sapphire 4870 1GB toxic + Arctic Cooling accelero twin turbo
Case: NZXT Whisper
And the other thing are no really mather to tell you.
It's 21 degree in there with AC on and it's HOT! but there I go with result and picture:)
#1 there is my (pro? lol ) test bench
So start with Idle stock at 2.83
CPU = 25 core = 34/34/39/39
Stock full load @ 2.83
CPU = 42 core = 46/43/47/44
Idle OC 3.8Ghz
CPU= 29 Core =35/34/39/39
Full load @ 3.8
CPU = 50 core = 52/48/53/51
I would really like if some one can tell me how to separate picture and put text between photo;)
Thx
Ask if you want more about the Cooler or the test method.
  #46 (permalink)
Old July 20, 2009, 09:05 PM
JD JD is offline
Pretty decent temperatures, though the way you have it mounted is basically open-air and your ambient is damn cold. 21C is crazy, David Suzuki would hate you
As per your pictures, use the VB Image Host at the top to upload your photos. Then take the BB Code IMG string and paste that into your post where you want the image. Then you can type around it.
  #47 (permalink)
Old July 21, 2009, 04:06 AM
21 is cold? your kidding me it's freaking hot:P Yeah I know about open air and test reliability that's why don;t base you on my simple review but I have compare the vendetta open bench to ( don't post result )
Ask for more
  #48 (permalink)
Old July 21, 2009, 08:59 AM
JD JD is offline
lol, we keep our house at 24.5-26C and it's cool enough. Though the basement (where I am) is typically 19-21C, but it warms up quickly during my late night gaming If we kept the main floor at 21C, I don't even want to know how cold the basement would be or how crazy our electricity bill would be. BTW, maybe your humidity is too high if 21C feels hot. Or your body temperature is far different than mine.
Anyways, I still think I'll tell my brother to buy this. His case is rather lacking of cooling options so this should keep his CPU temperatures down so that I can overclock my good ol' E6600 back to it's 3.6GHz+ glory. I'll probably use the stock fan and a Zalman ZM-F3 for push/pull.
  #49 (permalink)
Old July 21, 2009, 09:55 AM
ahah no it's not humydity I only HATE heat:) I'm a cold quebec guys. Yeah BTW I really sugest to buy it. Even at 90 it was for me a nice add to my PC and allow me tu use my vendetta 2 in a secondary system. One day NCIX will put it in sale and I will get another one:P
  #50 (permalink)
Old July 21, 2009, 01:09 PM
Sadasius's Avatar
Yeah same here. Nice Baph BTW! Pretty good temps on your setup. The push/pull fans in open air and great ambient do help a great deal. If some kid in Brazil tries this without heavy duty a/c, his CPU will be up in smoke.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
[WTB] cpu cooler(LGA 775) and air cooler for 9800gt j-ronde Buy/Sell & Trade 0 March 11, 2009 10:06 PM
