  #21 (permalink)
Old June 16, 2009, 04:09 PM
everything arrived today. will post pics when im all done just want to finish this hopefully by the end of tonight. had to flip my top rad around barbs were gettinng inn the way of 1 of the hard drives.
  #22 (permalink)
Old June 16, 2009, 09:30 PM
well got everything installed to make a test run. and got a long beep and then turned off. tried resetting the cmos but no luck tried removing ram no help tried removing video card no luck. maybe i should move this to another thread. the other funny thing is that the computer is turning on by itself.i upload sum pics. i also tried a different psu. im stuck for now.
  #23 (permalink)
Old June 17, 2009, 07:08 AM
Sadasius's Avatar
Your leak testing hot? Usually you don't leak test that way unless you really know what you are doing and heck even then. I never leak test hot ever and I have a few builds under my belt. Usually you grab a crappy low wattage PSU and make it run by using a paper clip or cutting and tweisting the green and black wire together to make a leak testing PSU. This way nothing on the board ot your PSU in your case gets powered up just in case you have a leak. Now you say your computer is turning on all by itself? Damn hopefully that is not due to a leak. Read this --> So how does this look for my first WC attempt?
Leaks can sometimes be extremely small or a very slow drip. Hopefully everything is alright.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
  #24 (permalink)
Old June 17, 2009, 07:43 AM
no leaks.just the long beep of death. the motherboard,cpu, and motherboard were used in my old setup in my old case. after fooling around with it for a couple of hours i have given up guna try and order a new mb.
  #25 (permalink)
Old June 17, 2009, 08:17 AM
Dazmode's Avatar
For future consideration: That's why I always assemble parts without any watercooling first. If something doesn't work, you don't need to guess where the problem is.
Try simple stuff: Re-seat memory, other PSU....
Orange Build: Final Video
HTPC Build: Final Video
  #26 (permalink)
Old June 17, 2009, 11:45 AM
i reseated the memory tried clearing the cmos, tried a different psu. just going to buy a new mb today.
  #27 (permalink)
Old June 17, 2009, 01:52 PM
Dazmode's Avatar
Did you installed CPU right?
  #28 (permalink)
Old June 17, 2009, 02:11 PM
of course. ive been working on computers for 10 years.i am just new to watercooling as ive only done it on a few computers. and as far as leaks thats why i use hose clamps 1/2 barb with 7/16 tubing havent had a problem yet, fits nice and tight. i know people get leaks from time to time it happens.it would definitly be smarter to do a leak test before installing it, i choose not too just like people does install hose clamps. im going to pick up the mb in a few hours when i get off work will let you guys know what happens.
  #29 (permalink)
Old June 17, 2009, 02:17 PM
Dazmode's Avatar
I'm not questioning anything. Just quite often things don't work because of small stupid thing that went wrong...
  #30 (permalink)
Old June 17, 2009, 03:15 PM
i hear ya ur definitly right.
2X120mm rad dual gpu+cpu loop nckid4u Water Cooling 19 May 12, 2009 06:05 AM
WTB: E8xxx cpu, s775 water block & single 120mm rad 4wdrive Buy/Sell & Trade 0 November 9, 2008 08:32 AM
TJ-07 dual loop help.... turtletrax Water Cooling 17 August 13, 2008 05:56 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 04:39 PM
9800GX2 on a single 120MM rad.... Cptn Vortex Water Cooling 37 May 20, 2008 10:38 PM
