Old June 14, 2009, 06:50 PM
im confused now, we have 2 different ways so far. if someone could fill the blanks in my crappy drawing i would be alot happier and not so stressed thanks. should i change the top rad around? ive been looking around on some threads and they seem to be putting a rad in between like pump, res, nb, cpu, rad gpu rad??
MCR320 -> CPU -> NB/SB -> GPU -> Res -> Pump -> MCR220 -> back to MCR320 ??
Old June 14, 2009, 07:10 PM
Dazmode's Avatar
I would do two loops, but
One of the options:
Orange Build: Final Video
HTPC Build: Final Video
Old June 14, 2009, 08:38 PM
Jackquelegs's Avatar
How about Pump--> MCR320 --> CPU --> NB --> MCR220 --> GPU --> Res --> Pump
Iapetos
Zephyranthes
Old June 14, 2009, 08:56 PM
Dazmode's Avatar
Bit longer tube runs (I think), but good too.
ps Do you have equipment already?
Old June 14, 2009, 10:27 PM
Sadasius's Avatar
I like what you did in your pic and I think that will work out for you perfectly. Something else you may want to consider is a drain. Makes it so much easier and you can just a t-line for that and bend it down to make it the lowest point when you need it. When your not using it just tuck it away out of sight.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 15, 2009, 04:21 AM
dazmode- most stuff came already, waiting for another rad, some tubing, nb block and gpu block,clips,lights, fans, fan extentions mosfet hs. -> coming from florida. sadasius- a t-line between pump and res as a drain? am i getting that right?jackquelegs-> thats also what i was thinking but would definitly be the longest route.
Old June 15, 2009, 05:46 AM
Dazmode's Avatar
Instead of T-line you can add another barb and piece of tube to the bottom of reservoir.
Old June 15, 2009, 05:50 AM
thats what i was thinking. im guna have to goto the local pc store pick up a few things ill just add that to my list.
  #19 (permalink)
Old June 15, 2009, 07:15 AM
Sadasius's Avatar
Yeah pretty much whatever will work best with your build to use as a drain. Comes in so handy instead of pulling a hose off quickly and hoping for the best.
Code:
  #20 (permalink)
Old June 15, 2009, 07:35 AM
Dazmode's Avatar
Forgot to mention... you need stop fitting to close your drain tube... :)
2X120mm rad dual gpu+cpu loop nckid4u Water Cooling 19 May 12, 2009 05:05 AM
WTB: E8xxx cpu, s775 water block & single 120mm rad 4wdrive Buy/Sell & Trade 0 November 9, 2008 08:32 AM
TJ-07 dual loop help.... turtletrax Water Cooling 17 August 13, 2008 04:56 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
9800GX2 on a single 120MM rad.... Cptn Vortex Water Cooling 37 May 20, 2008 09:38 PM
