<~----> Clean your Rads. A lesson - Hardware Canucks
Old June 13, 2009, 04:13 PM
Cptn Vortex's Avatar
Default Clean your Rads. A lesson
Hey all. I just finished installing my machine into a new case, and thought I would share some insight. I had my 2 x 320mm rads installed for about 1 year. I didnt think dust would be so bad, my place is hardwood floors and I have no pets... Anyway here is what I found when I removed my fans:
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old June 13, 2009, 04:15 PM
Didn't we comment about how dirty they were at the last LAN?
How much did cleaning help your temps?
Old June 13, 2009, 04:19 PM
yea, but I didnt think they were this bad. And I cant really compare temps, new case, different fans, different layout.... They look to be about the same temp though. Also merged my 2 loops into 1, so that may have something to do with it
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old June 13, 2009, 05:33 PM
FlyingFish's Avatar
Good Gawd...
I guess the neons hide the dust well?
Old June 13, 2009, 05:41 PM
MpG's Avatar
MpG MpG is offline
Oh yeah, been there many times. And damned if I can find a filter that works, but doesn't murder the airflow. These days, my approach is to give up on filtering, and just make the rads as easy to reach with a vacuum cleaner as possible.
Old June 13, 2009, 05:59 PM
3 of 7's Avatar
I bought a "tire pig" It's basically a 7 gallon air tank.. I fill it with my compressor out in the shop and bring it into the house every now and then and make one hell of a mess LOL
Then I vacuum the house.
Nature always sides with the hidden flaw
Old June 13, 2009, 06:58 PM
Sadasius's Avatar
Damn.... That's pretty bad. Time for a good cleaning!
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 13, 2009, 07:28 PM
JD JD is offline
Mines probably worse...
2 cats, hardwood floors, and I've been fixing up the walls to get ready for some new paint so there's a bunch of Polyfill dust floating around too
The last time I cleaned it, it looked like this:
I'd take a guess and say its the same, or worse now. However that was with push/pull P12s, now I'm just running pull S-FLEX "F"s
Old June 13, 2009, 07:38 PM
Mmmmmm tasty!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old June 13, 2009, 07:39 PM
Sadasius's Avatar
I use filters.... They help keep temps stable and keep your rad from trying to make a sweater.
Code:
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Question: one MCP655, two rads and SLI? Babrbarossa Water Cooling 4 November 8, 2008 05:27 AM
LF: Black Ice Xtreme Rads chibi_man Buy/Sell & Trade 2 September 2, 2008 04:06 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
Intel gives Anandtech a Yiddish lesson: Nehalem and Gesher Babrbarossa Press Releases & Tech News 1 March 29, 2007 09:27 AM
