Old June 14, 2009, 12:44 AM
shumway's Avatar
Thats a ton of dust man,
Tore my comp apart yesterday for a clean and my vendetta 2 looked just as bad
Old June 14, 2009, 01:29 AM
Phobia's Avatar
oman, i really need to take my PC apart. I've been debating doing it for the last few weeks.. i think this thread has motivated me to do it.
(whitty saying to be plagiarized at a later date)
Old June 14, 2009, 03:44 AM
Wow haha, I thought mine was bad cause it had a hint of grey. Mine is about 6ft above the ground so that helps.
Old June 14, 2009, 05:04 AM
sswilson's Avatar
Originally Posted by jdrom17 View Post
Mines probably worse...
2 cats, hardwood floors, and I've been fixing up the walls to get ready for some new paint so there's a bunch of Polyfill dust floating around too
The last time I cleaned it, it looked like this:
I'd take a guess and say its the same, or worse now. However that was with push/pull P12s, now I'm just running pull S-FLEX "F"s
At least as an enthusiast you're aware of the requirement to clean up every now and then......
Hands up.... how many folks have opened up a friend's/family computer which has sat on the same shelf for 3 - 5 years without moving an inch? Nothing like a 1/2" blanket of dust/pet hair completely covering the entire motherboard....... :)
Thanks for posting this Cptn Vortex. It's a good reminder for me that it's coming up on the 6 month mark since I took apart the Cosmos S and gave it a good cleaning. (Did the front bays and outside last week... :) ).
Old June 14, 2009, 09:08 AM
zlojack's Avatar
I use filters and clean them once a week.
I still get some dust in my case, but I usually clean that out with compressed air on a semi-regular basis.
Old June 14, 2009, 06:33 PM
JD JD is offline
lol I'm aware but I just get lazy...
My case internally is pretty clean thanks to the positive pressure =) Just that darn radiator hanging off the back that gets so dirty.
And yeah some PC's I've worked on were dirty but not THAT horrible.
Old June 14, 2009, 06:40 PM
Supergrover's Avatar
I use filters on my intakes so the inside isnt too bad, Rad is on the back and look about the same.
Every 6 months I'll tear it down and soak the rad clean. Tubes are usally ready for a change by then anyways.
JD: I justt remembered you have those quick disconnects for your rad, should be super easy to clean it.
Old June 14, 2009, 09:36 PM
Cptn Vortex's Avatar
I like this new ATCS case, all intakes are filtered :).
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #19 (permalink)
Old June 15, 2009, 08:11 AM
JD JD is offline
Yeah but they still leak some fluid and gets air into the loop. Not as ideal as I hoped for.
I want to get a new reservoir (XSPC Dual Bay Res for DDC) but Jabtech's shipping is ridiculous. I'm hoping Performance-PCs or Sidewinder gets it in as well. It'll solve my pump/res issues as well since it's made exactly how I want. So when that time rolls around, I'll clean everything. Until then, f*ck it
  #20 (permalink)
Old June 15, 2009, 08:30 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Mine look teh same or worse after a few months. I clean em often.
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Question: one MCP655, two rads and SLI? Babrbarossa Water Cooling 4 November 8, 2008 06:27 AM
LF: Black Ice Xtreme Rads chibi_man Buy/Sell & Trade 2 September 2, 2008 04:06 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
Intel gives Anandtech a Yiddish lesson: Nehalem and Gesher Babrbarossa Press Releases & Tech News 1 March 29, 2007 09:27 AM
