<~----> What Tubing Do You Use? Did it Cloud? - Page 4 - Hardware Canucks
  #31 (permalink)
Old June 17, 2009, 10:29 AM
Dazmode's Avatar
What kind of filter is that?
Orange Build: Final Video
HTPC Build: Final Video
  #32 (permalink)
Old June 17, 2009, 11:56 AM
gingerbee's Avatar
looking forward to the results. very cool thank man
  #33 (permalink)
Old June 17, 2009, 12:46 PM
Sadasius's Avatar
It's a Pentek Filter clear casing without the bypass button. Usually they are blue with a red bypass button. Did not need a bypass button so I got the cheaper white one without. The filter itself is a Pentek 5 Micron sediment filter. The main idea is to see if things can be fixed, reversed or whatever outcome and record it. I am hoping this will trap whatever is inside the loop causing this problem. If I have to I will send the damn tube to a lab for analysis of the damn white stuff to see what it actually is and how it could have been caused.
Same here. Soon we will have some answers and hopefully not more questions.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
  #34 (permalink)
Old June 17, 2009, 12:51 PM
Dazmode's Avatar
If you want my tube, I can send it to you... 3 weeks on water, Tygon tube.
  #35 (permalink)
Old June 17, 2009, 12:56 PM
Sadasius's Avatar
That's okay I got a bunch of them myself.... Even got some old Primochill red with some white stuff in it. That's what I am using on the filter actually...Well clean one's not the dirty one's.
Code:
  #36 (permalink)
Old June 17, 2009, 01:01 PM
Dazmode's Avatar
Sorry for being n00b... Where do you buy those filters? Water Depot or something?
  #37 (permalink)
Old June 17, 2009, 01:08 PM
Sadasius's Avatar
Got it from http://www.filtersfast.com. The shipping is expensive but quick. They come in many sizes and you have to watch what threading as well. They do come in 1/4" threading so watch for that.
Code:
  #38 (permalink)
Old June 18, 2009, 01:56 PM
Sadasius's Avatar
Okay news update...Will update with a pic tonight. Not going to make any conclusions yet but the filter is working really well and it seems to be reversing the damage to the tubes. I will take a picture and have a side by side comparison to the older pic to see if my eyes are not playing tricks on me.
I am starting to think it is leftover flux from radiators. Now I know some radiator manufacturers clean their rads prior to sale and others do not. I bet you if we asked which rads were used when the clouding happened we would get a consensus of what company cleans and who does not. The reason why I think it is leftover flux is because it oxidizes metal so that it can bond better with solder. It is why it is used in rads. I just so happen to have flux at home and I will be doing some swab tests at home to see if it is the tubes getting oxidized. Would explain so damn much such as why some tubes cloud quicker then others (some oxidize quicker due to their manufacturing differences).
Code:
  #39 (permalink)
Old June 18, 2009, 02:02 PM
Dazmode's Avatar
I can confirm then, that Swiftech and Feser are both cloud tubes.
Feser recommends 8 flashes with hot water and advise against vinegar.
  #40 (permalink)
Old June 18, 2009, 02:11 PM
Sadasius's Avatar
I can confirm HWLabs and Thermochill then too. Mind you the HWLAbs is not as bad as some which makes me think they somewhat clean theirs prior to shipment. Also read up as well that the flux when burned with solder does actually become acidic. Too bad I don't have PH strips for more tests. Will have to look into that.
Code:
Tags
clouding , tubing
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
Tubing and Tube Coils miggs78 Water Cooling 21 August 16, 2008 06:51 PM
Cutting tubing elninio Water Cooling 11 June 10, 2008 04:14 PM
Fans for WC and tubing Dashock Water Cooling 7 May 5, 2008 10:13 AM
Tygon tubing Dark Water Cooling 5 December 28, 2007 07:42 AM
